| Small clear oil leak under nearside of engine Hi Can anyone help? Just bought a 1995 Panda Colour, after parking it on the drive I have noticed what i originally thought was a small water leak. On closer inspection it is clear oil. It is below the nearside of the engine...any ideas? Thanks Steph
| Moderator | Re: Small clear oil leak under nearside of engine I don't think I've had a Panda that doesn't leak from somewhere. Leaking oil from the rocker cover gasket is a particular Panda favourite.
| | #3 | ||
| Moderator | Re: Small clear oil leak under nearside of engine Just to add, unless it's leaking transmission oil I would live with a leak from the engine as long as it's not too bad. It saves you changing oil if you're topping it up every so often.* * Tip number 8 in Steve's forthcoming book "How Not To Run A Car".
| | #4 | ||
| Be careful that it is not a torn driveshaft gaiter as you will be losing gearbox oil. The gearbox oil and engine oil are independent of each other.
__________________ * * * Pandarus * * * (aka MARTIN) FIATLESS BUT STILL LOVING ANYTHING PANDA!!! 2002 Skoda Fabia Comfort Estate 1.4 MPI | |||
| | #5 | |||
__________________ * * * Pandarus * * * (aka MARTIN) FIATLESS BUT STILL LOVING ANYTHING PANDA!!! 2002 Skoda Fabia Comfort Estate 1.4 MPI | ||||
| | #6 | |||||
| | #7 | ||
| Thank you, where do I check the gearbox oil? Sorry not very mechanical
| | #8 | ||
| Moderator | Re: Small clear oil leak under nearside of engine The driveshaft gaiter. If there is oil leaking from that it will kill your gearbox. Get it sorted asap. Do you have a Haynes or Porter manual? If not then it would be a good investment.
| | #9 | ||
| Re: Small clear oil leak under nearside of engine Thanks Steve. I will get a Haynes manual. In the mean time where do I check and top up the gearbox oil and which oil is best to use?
| | #10 | ||
| Silent Surveillance | Re: Small clear oil leak under nearside of engine
__________________ | ||
| | #11 | |||
If you can tomorrow, flip your bonnet (for extra light) and pop underneath to have a look at the rubber gaiters for rips. One of my gaiters was torn when I got my Panda last year and I got a garage to fit a new one for about £60 (I'm not as clever as some of the brillian mechanic types on here but I am learning!).
__________________ * * * Pandarus * * * (aka MARTIN) FIATLESS BUT STILL LOVING ANYTHING PANDA!!! 2002 Skoda Fabia Comfort Estate 1.4 MPI Last edited by Pandarus; 22-02-2006 at 22:50. | ||||
| | #12 | |||
Dead envious me - sun roof envy.
| | #13 | |||||
Yes, that is mine. Picked it up on Sunday......I love him
| | #14 | |||||
Thanks Martin, will look tomorrow.
| | #15 | |||
| Northern Ireland | Re: Small clear oil leak under nearside of engine
You've got Juppy's Girlfriend!!!! (Richard restored Juppy before I bought him!) Jim | |||
| | 95-Cinq-899 | Cinquecento / Seicento | 2 | 20-12-2005 13:32 |
| fiat ulysse oil and filter change | jamx2 | Ulysse | 10 | 03-10-2005 22:18 |
| | DTournay | Punto | 5 | 29-09-2003 04:38 |
| | thetman | Stilo | 6 | 12-07-2003 00:30 |
| | AndrewMallia | Punto | 4 | 05-01-2003 05:07 |
