| 1986 March 965cc Panda 4x4 gearbox et al Hi, Anyone changed the hardy spicer joint (adj to diff) on rear propshaft of 965cc 1986 Panda 4x4? - I am about to start the exercise armed with the Porters Manual. Just wondered if there are any snags? I have also located a s/h flywheel and intend to start dropping the gearbox over Christmas Hols. Got a new Valeo clutch kit at £57 UKP del to door. Any hints for dropping gearbox / aligning clutch? Porters imply drawing both hubs from driveshafts and pulling out gearbox complete with drive shafts - why can the driveshafts not be removed from the gearbox after drawing hubs off the splines - I seem to remember being able to remove drive shafts after I overhauled hub carriers a few years ago - any comments? Tom tjs
| Removing the driveshafts helps you to handle the gearbox,which will be lighter;)!Of course on a 4x4 model you'll need to dismantle the transmission shaft to do the clutch!If you've got the manual read it,and possibly compare the different solutions from different books:p!
| | #3 | ||
| Best thing for aligning a new clutch is an old gearbox input shaft... Regarding hubs and driveshafts, I did one inboard driveshaft boot by taking the hub off: it was a real pain to split the bottom suspension joint, and the hub "staked" nut was beyond redemption and cost rather a lot to replace. The other one was done with the hub left fastened to the driveshaft[:0] so the nut was undisturbed. It was awkwark to refit - primarily due to the hub and some of the suspension weight being mauled about while getting the tripod joint back in. But I did it on my own. BTW I took the suspension to bits (like this thread http://www.fiatcentral.com/forum/topic.asp?TOPIC_ID=5253) rather than split that joint on the second side I did.
| 1986 4x4 Panda renovation | waddow | Panda (Classic) | 3 | 16-02-2006 18:04 |
| 1986 Panda 4x4 queries | waddow | Panda (Classic) | 10 | 18-02-2004 20:18 |
| Resendt - 1986 not 1985 Fiat Panda 4x4 | waddow | Panda (Classic) | 12 | 23-10-2003 14:39 |
| Panda Gearbox | steveyensen | Panda (Classic) | 62 | 09-07-2003 16:21 |
