Thread Tools
Old 3 Weeks Ago   #1
pooroldcodger has donated!
can anybody help identify this bit?
Good morning all.
I have a 1994 Panda Colour which I have been gradually working on as my first project car . I have arrived at the front passenger side sill area .
I have done some research and realise that there are 3 layers, floor, inner sill and outer sill all coming together at the seam under the sill and originally spot welded together. However I have cut out a section of inner sill and come across this section which looks like an extra reinforcement piece. Should this section also continue down to the sill seam and be included in the "sandwich"?
Should it continue right up to the front end of the sill in to the wheel arch area or does it finish where mine does?
This vehicle has had various mot-type repairs before I owned it and at this stage I am looking to make it safe and road worthy, and if it proves to be mechanically ok (within reason for an old car!) I may decide in future to put new sill panels on (which I already acquired some time ago).
Any images that you have would be great, thank you.
pooroldcodger is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
It look like the inner sill at the spring hanger box near the rear wheel or is it a the front foot well ? Yes it should be included
Theres an option. To weld the inner sill and floor pan together using mole grips to pull them weld up move Along the rusted area seaming together then grind straight adding a single connection of steel to the outer sill pretty easy for repairing Click image for larger version
ID:	183946Click image for larger version
ID:	183947Click image for larger version
ID:	183948Click image for larger version
Finished section
Sjvarley is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Re: can anybody help identify this bit?
Thanks a lot!
Yes it is the front passenger side. Here is a shot from a bit further away .
So the piece that you can see that is rotted through should continue down and join in the sill seam?
Old 3 Weeks Ago   #4
Panda Wanda
kolza's Avatar
Trader Rating: 1
kolza has donated!
Thanks pooroldcodger thanked for this post
Likes Sjvarley, pooroldcodger liked this post
Sisley '89
Formula '91
W123 230CE '83 - project for sale 400
Subaru Legacy GT-B '98
kolza is offline Reply With Quote Quote
Old 3 Weeks Ago   #5
Briiliant thank you!
Old 3 Weeks Ago   #6
Quote Originally Posted by pooroldcodger View Post
Ok if you can get acsess from
Under neath or put the car on its side would be best cut away the rot and gain acsess through the floor pan pretty simple then reweld. Otherwise cut of the whole sill repair front and rear stuffing panels this is where 4 sections m join check out @kolza. &. @panda1408 digger theads to see the full extent of the work required
Old 3 Weeks Ago   #7
panda1408 has donated!
About the best photo I can find at the moment, you can see the piece you are talking about behind the A post stiffener.
It should go right down to the sill seam and as far as I am aware it is originally tied into the inner arch and A post stiffener at the front. On all the cars I have looked at or repaired in that area, it is always very rotten and hard to work out how exactly it went together.
Unless you are cutting off the outer sill its will be difficult to put it back exactly, if you can join it back to the main sill seam then that would suffice.
Likes Sjvarley liked this post
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 2 Weeks Ago   #8
Thanks guys. As the top part seems to be very solid I am going to cut it back to solid metal and a straight edge and joint a new section in and finish it at the sill seam.
Old 2 Weeks Ago   #9
Thank you for that. Just one question - what are the "stuffing panels"?
Old 2 Weeks Ago   #10
Typo stiffening as mentioned in Freddy's write up
Likes pooroldcodger liked this post
Old 2 Weeks Ago   #11
I would have thought that stuffing panels are where you are totally stuffed and out of options.
Too rotten, or in modern terms beyond economical repair.
Dave
pandamaniac is offline Reply With Quote Quote
Old 2 Weeks Ago   #12
Yes I have felt stuffed on many occasions!
Thanks for the help and encouragement guys.
One more question if I may.
On the passenger side under the wheel arch, having taken off the main liner I came across this plastic panel clipped to the seams at the join between the end of the sill and the bulkhead. Image attached. There isn't one on the driver's side. I am guessing there should be?
Thread Tools
(G) Help Identify please lisaleeds Punto (Mk2/2b) 14 30-05-2013 13:48
Buying Instal Bit By Bit (Sub and Amp Help) Mr Cousins I.C.E 18 05-04-2010 23:26
(T) Can anyone identify this..... deebeepee Grande Punto 7 09-03-2010 10:28
(G) Help Identify my X1/9 Aldino X1/9 4 25-08-2008 09:19
Isn´t Bravo´s Vans rear, a little bit bit loose at High Speeds? Tiago Ferreira FIAT Boo Archives 1 20-09-2001 17:09
