I need some help. Recently i bought 1992. Panda 750 FIRE and i want to check the oil but i cant find the dipstick. Can you please tell me where could it be located or did Panda even come with a dipstick. Thanks.
It's behind and down from the oil filler area. So, when you open the bonnet, look to the top left of the engine and see the black filler cap/bung, behind the top of the engine from looking at this angle and downward towards the sump and you should find the dipstick. I assume this is the same on the 750 as it is on the 1000 at least as other than capacity I don't think there is much difference. Hope this helps
