Thread Tools
Old 18-08-2017   #1
Maranellohouse.com
Stuartl's Avatar
Trader Rating: 3
Stuartl has donated!
Glop 3 Champion, Desert Battle Champion
Early metal MK1 grill fit a a MK2
Just an idea, does anyone know or has tried to fit a metal MK1 grill in place of the plastic one on a MK2?
Also wonder if MK1 bumpers will fit on a MK2. Thinking of a swap for the van to make it look older than it is.
Thoughts?
Stuartl is offline Reply With Quote Quote
Old 18-08-2017   #2
Re: Early metal MK1 grill fit a a MK2
Grill yes. Bumpers ask Freddy he will know @panda1408
Sjvarley is offline Reply With Quote Quote
Old 18-08-2017   #3
panda1408 has donated!
Never tried a Mk1 bumper on a mk2 but as far as I know the mounting points are the same so it should go straight on. The grille will require the fabrication of some mounting brackets.
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 18-08-2017   #4
I replaced my grille with the early metal mk1 grille type a while back. After re-doing the grille I set about trying to attach it as the mounting points are not the same. To start with, I just cable tied it in each corner of the grille to the nearest mk2 mounting points.
I came up with a solution quite soon after. My father had found some metal plates that were the perfect size for going from the holes in the mk2 to go and bridge the gap to the mk1 grille mounting points. After modifying the plates slightly and making sure the holes were in the right places, just secure it up!
The center holes are the same for the mk1/mk2 so that's easy enough
The front facing mk2 points are the hardest to fit I found. There is not much room to work with. For this design, we bent some metal to shape, where it screws into the mk2 mounting point and joining to the flat of the bottom of the mk1 grille. Again, drill holes and secure, though securing this one is a bit more fiddly given there is not much space. If you're taking the bumpers off, I imagine you can come up with a good solution for keeping it extra secure on the bottom there!
As you may see in the first picture, the mounts bend down slightly, I believe this is because of the front facing mk2 mounts. The mounts on the car get in the way and almost prop up the mk1 grille because the mk1 grille has extended sides. One solution would be to trim the sides of the grille I'd imagine, which would let you mount it in a position more of your own choosing rather than where it wants to sit. Not saying it doesn't work without modifying the grille though, here is the finished result!
I plan on repainting the grille one day so I'll end up making the mounts a bit prettier too, but there's a rough guide to it - hope that helps, but yes, long story short, the mk1 grille can fit if you make the mounts to fit!
FDNY21 is offline Reply With Quote Quote
Old 19-08-2017   #5
Inept fettler
northernchap's Avatar
northernchap has donated!
I appreciate that you're more than likely doing it properly, but just for anyone else who might read this - all of the above is true, but you can also get away with just using the centre mounts to hold it in place, and putting cable ties through the lower holes and securing them against the existing mounts. It stays in place perfectly well, and lets you try it out for a while if that's your bag.
88 Panda 4x4 - Still more welding required.
91 Peugeot 309 GLD - The ultimate practical classic. Awaiting MOT.
65 Mustang - broken as usual. Last moved August 2015.
92 Citroen BX TZD Estate - Running well for the moment...
northernchap is offline Reply With Quote Quote
Old 19-08-2017   #6
Quote Originally Posted by northernchap View Post
I think the front facing mount on the left hand side (without the vents) is still held on by a cable tie on my car too, I second you saying it stays in place perfectly well! It is very fiddly getting that metal mount in there on the front facing mount so think I may opt for ties next time I fit anyway... I did so when I first fit the grille but wanted something that looked a bit more in place. Think I may tie the bottom with red ties and paint the top custom mounts I have red, that should fit in nicely!
Thread Tools
(S) does this fit my GP. grill with bagde? not the bottom grill HaydensPunto Grande Punto 6 25-02-2014 13:50
(G) What Mk2 Parts fit a Mk1? Manson91 Punto (Mk2/2b) 10 13-01-2010 11:19
(T) mk1 exhaust fit the mk2? seanMcPot Punto (Mk2/2b) 0 26-05-2009 23:01
