Technical Fiat panda transmission
KANADOS
Hello folks I'm hoping I can get some assistance.
I have a 1991 FIAT PANDA and I'm having transmission issues.
The issues are varied and I'm pretty much thinking my solution is to possibly replacing the entire transmission.
I have a mechanic that can do the labour.
Its a matter of sourcing all the needed components and parts.
Can I be steered in the right direction ?
thank you in advance for your time
A little more info required type model problem please 4x4 ?2wd ? selecta?? Issues involved drive train? Gearbox ? Selection? Noise ? Jumping out of gear?
Good day folks.
I just wanted to follow up my post.
Upon further inspection I believe I found what the issue is.
- I need to source out a ECTV MODULE 30522KA070
- Also am looking for an Engine & Transmission wiring diagram for 1991 FIAT PANDA with SELECTA cvt transmission
Please let me know......
thank you in advance for any help (y)
I found the ectv
Posted on the panda part request thread
[emoji1360]
Hello folks...its been a while.
I hope everyone is well.
I am looking to go another route possibly.
Would ot be possible to convert my Panda whicb is th3 SELECTA CVT transmission to MANUAL ?
Has anyone done this before ?
What did ot entail ?
Thank you for your input
It would likely cost more the the value of the case as it would need replacement gearbox linkage's gear shifter
Also likely to to a ECU out of a manual car and possibly dashboard clocks as well
