Thread Tools
Old 31-07-2017   #1
Magentas story 4x4 rebuild
Those who have seen our previous posts will know how we purchased 3 4x4 pandas for 600 well one has now died one has become the big Green panda
So on to the third Magenta
Which is looking pretty good
Started and ran the engine for 1st time since 2003 .[
Started to strip her Click image for larger version
Panda Brian off to Italy leaving Magenta behind Click image for larger version
ID:	182842Click image for larger version
ID:	182843Click image for larger version
ID:	182844Click image for larger version
Alll in all not so bad a bit of floor pan rust and rear panel
As for the sill tops and window edges I am very happy
Full Strip this weekend then get welding
Magenta being collected October 31 2016
Likes AndyPanda4x4, FDNY21 liked this post
Sjvarley is offline Reply With Quote Quote
Old 31-07-2017   #2
Moving on to what is planned for Magenta
I am thinking about 2 directions to go either using all the knowledge from Brian to make another big panda but with the addition of a live rear axel utilising swing arms. coilovers and panrod linkage
Or to go for a full connection isolation from the suspension to make her far smother to
Drive and quieter in the cabin i.e. Home made sub frame isolators
Or even a mix of both ?
Old 05-08-2017   #3
Had today off work so set into stripping out Magenta from the back to front planning to set her up on a home made spit making it easy to weldClick image for larger version
Likes andyholli, AndyPanda4x4 liked this post
Old 06-08-2017   #4
Rollin' On Steelies
AndyPanda4x4's Avatar
Trader Rating: 1
AndyPanda4x4 has donated!
Re: Magentas story 4x4 rebuild
Was the TV fitted to it aswell?!
Fiat Panda 4x4 - What the Yorkshire Dales were made for.
AndyPanda4x4 is offline Reply With Quote Quote
Old 06-08-2017   #5
Quote Originally Posted by AndyPanda4x4 View Post
Well that was free with loads of other stuff too soft tops for a triumph jack leather jacket solicitor case file full set of mats t
Jack for a stag 8 ski racks for Sisley spare dash speakers mice snails pens pencils keys sweets lighter Triumph parts list triumph workshop manual house key for an address in France to keys for an aero vac whatever !!!
Old 06-08-2017   #6
Magenta now stripped down and on the spit. Chopped out some rot
Assessed the repairs
Absolutely no body rot all floor pan work brilliant
Old 06-08-2017   #7
ID:	183099Click image for larger version
ID:	183100 Click image for larger version
ID:	183101Click image for larger version
ID:	183102Click image for larger version
ID:	183103Click image for larger version
ID:	183104 spot that snail
ID:	183105Click image for larger version
ID:	183106Click image for larger version
ID:	183107 can't believe these sills the other Sisley had rotten sills and intact inners rotten body panels roof line door tops door bottoms sill tops but perfect leaf supports and inner arches !!!
Likes AndyPanda4x4 liked this post
Old 06-08-2017   #8
Rollin' On Steelies
Trader Rating: 1
Proper job that Steve.
Likes Sjvarley liked this post
Old 06-08-2017   #9
Full strip then rebuild that way we will find all the pitfalls first
Old 06-08-2017   #10
As above
Old 07-08-2017   #11
Decided on trailing arms for this one just got make a decision on the axel connection type
Old 11-08-2017   #12
Chopping out the rotClick image for larger version
The inner sill and floor pan had rotted away on the near side
Soulution cut back then grip together weld the 2 edges into one Click image for larger version
Inside view Click image for larger version
Create a new floor pan and then weld to the jointClick image for larger version
Gas just ran out
Old 12-08-2017   #13
The first 45 cm of sill complete
Hammer test. All good next tackle this hole Click image for larger version
Running total hrs now spent since putting her in the workshop
23 hrs.
Likes AndyPanda4x4, Yorkshire007 liked this post
Old 4 Weeks Ago   #14
Well few more hours have passed both sill now complete rear hanger boxes rebuilt now closing Down the floor pan under the rear seat . Photos to follow. 28 hrs. Now !!
Likes AndyPanda4x4, andyholli liked this post
Old 1 Week Ago   #15
Update on progress welding now 95% complete just a couple of inside patches to complete 1 hour or so. Click image for larger version
Suspension strengthen plate
Cross member now without jacking point
Now trying to set up albeit temporary the swinging arms
Either 3 link or 4 link with a panard rod positions of springs either directly over the bump stops or slightly forward this would give more travel
Proposing to use the front springs. As a bench mark (keeping it fiat ) collapsed length of 150 extending to 355
This may not be sufficient
Longer tie rods going to the centre cross member would allow fuller articulation problems noted are the true will come in contact sooner against the triple seam in the wheel arch to over come this it may be best to have a panhard rod resulting in the axle moving sideways like a pendulum Click image for larger version
ID:	184199 Click image for larger version
ID:	184201Click image for larger version
31 hours now
ID:	184200   Click image for larger version
Likes Alixcompo, andyholli liked this post
Thread Tools
(S) The story so far ItsMagix Punto Evo 2 22-03-2015 22:32
(T) 4x4 rear axle strip and rebuild rustypanda Panda (Classic) 21 08-10-2014 13:41
(G) Story so far MultiPLF Multipla 1 28-07-2010 17:43
(G) 4x4 rebuild underway! Crashtest33 Panda (Classic) 68 11-09-2008 09:02
(G) The 4x4 rebuild engine Q's Crashtest33 Panda (Classic) 16 10-09-2008 22:53
