Thread Tools
Old 25-06-2017   #1
Torridon1 has donated!
How long does a metal vaned water pump last?
My 1992 CLX is running much hotter than usual. Climbing to just below the red quickly in traffic but cooling only a little on the move. No noticeable loss of power. Top and bottom pipes are hot, coolant a little low, but no white gunk in the oil.
So I search the forum, read some other posts and then come across a description of virtually the same problem, posted in Sept 2013 ....by me (#sheepish)
Naturally, re-reading the whole thread brought it all back. The solution last time was to replace the water pump (with a solid looking metal vaned one) and flushing the system with the garden hose.
I did it before so I know I can do it again, but I am surprised that the water pump has stopped working after 3.5 years. What could go wrong with it?
There isn't any noticeable noise coming from it and no evidence of leaking coolant on the driveway.
Could I be jumping to conclusions and be missing something else?
Torridon1 is offline Reply With Quote Quote
Old 25-06-2017   #2
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: How long does a metal vaned water pump last?
What was wrong with the old waterpump?
I've only seen three pumping failure modes on this type of pump
Corrosion or erosion of te impeller
Blockage due to contamination or corrosion
Impeller coming loose on shaft
The last is the most likely, IF it's a pump failure.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 25-06-2017   #3
Trader Rating: 1
portland_bill has donated!
Thermostat?
Likes Freebo liked this post
13 years motor trade, 16 years motor industry. 13 years Driving Instructor & 6 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 25-06-2017   #4
769cc Mayhem!
Didge3's Avatar
Didge3 has donated!
If top hose is hot as OP says shouldn't be t/stat.
You mentioned in traffic it approaches red, coolant fan cutting in and out?
FIAT-LESS
Didge3 is offline Reply With Quote Quote
Old 26-06-2017   #5
Fan seems to be working fine, kicking in as the gauge goes into the red, and stopping as gauge drops below red
Old 26-06-2017   #6
Air trapped in rad?check bleed screw?fill through bleed screw.
change thermostat , it may be opening late or may be not opening enough.
Fan should start before gauge reaches red.
Could be reduced flow flow through rad leading to fan switch heating slowly due to iffy thermostat.
jackwhoo is offline Reply With Quote Quote
Old 26-06-2017   #7
Rollin' On Steelies
AndyPanda4x4's Avatar
Trader Rating: 1
AndyPanda4x4 has donated!
The fan generally kicks in after the first mark just after the needle is straight upwards (can't say the exact dial measurement without looking at my car). If your fan is kicking in when the gauge gets to red, I am wondering if it's the earth fault that others are having at the moment which causes the gauge to advance further than it should.
Other than that, I'd agree with the other suggestions - is your heater matrix getting warm as well?
Fiat Panda 4x4 - What the Yorkshire Dales were made for.
AndyPanda4x4 is offline Reply With Quote Quote
Old 26-06-2017   #8
Thanks. I will open the bleed screws and get rid of any air
I will check if the heater matrix is getting warm
The fan has always started when approaching the red
Will report back
Thanks for the advice so far
Old 26-06-2017   #9
The tank at the side of radiator is an expansion tank for coolant. Picture it as a separate tank only joined to radiator by a hose going from bottom of tank to bottom of radiator.
if there is air in radiator fill through the bleed screw holes, small funnel useful. leave expansion cap on or you will end up with no expansion air space in tank.
Ooo casting my mind way back I may have used to fill these systems by removing the top most heater pipe and filling through that pipe. Doing it that way put rad bleed screw back in when coolant free of bubbles flows out.stop filling when coolant comes out of heater stub , make sure heater valve open when doing this.
Good luck.
PS add an extra earth wire from battery -ve to body it works wonders .
Old 26-06-2017   #10
PANDA!!
Freebo's Avatar
Freebo is part of the official FF Events Team :)
Freebo has donated!
Ghost Ball Champion
Best way I've found to bleed them is to get someone to keep an eye on the bleed screw and use your mouth over the expansion tank and blow putting pressure on the water to go through the system, once air has all come out the bleed screw tighten it up then run the engine and repeat if needed.
Freebo is offline Reply With Quote Quote
Old 27-06-2017   #11
769cc Mayhem!
Didge3's Avatar
Didge3 has donated!
Yes as mentioned the fan should switch on just past the midway mark on the gauge and typically turns off just under midway again.
I may be completely wrong here but does the dash temp gauge read from a different sender to the source the fan uses to switch on and off? I feel like I read that somewhere... If so could be the fan sender is out and telling the fan to come on much later it should. Or the gauge side of it is out and the gauge is reading hot when the engine isn't?
FIAT-LESS
Old 27-06-2017   #12
On panda mk1 gauge sender and fan switch are separate parts.
Fan switch is screwed into radiator.
Old 27-06-2017   #13
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by Freebo View Post
Don't do this with the engine hot
A radiator leak test kit often contain a cap with a hose fitting. This provides a safer method of pressure bleeding than mouth to expansion bottle.
Robert G8RPI
Old 27-06-2017   #14
PANDA!!
Freebo's Avatar
Freebo has donated!
Ghost Ball Champion
Quote Originally Posted by g8rpi View Post
Robert G8RPI
I only do this when cold, assuming if your bleeding it then the engine isn't going to be hot. Besides if it was I can't see any issues?
Old 27-06-2017   #15
Moderator
g8rpi's Avatar
g8rpi has donated!
The first issue is of course getting hot water blown back at you, examples being a thermostat opening or airlock releasing. You need the engine running to circulate the water.
Other issue is that coolant is toxic.
I have of course never done this myself
Robert G8RPI.
Thread Tools
(T) Water pump metal pipe started leaking chesh Punto (Mk1) 8 15-10-2014 17:03
Fiat Punto 1.2 8v 16v Metal Water Rail Pipe Tube - Water Pump 55188163 Fitting?? AndrewHenson Newbie Central 0 20-05-2013 12:55
(G) Metal water pipe Framey Punto (Mk2/2b) 1 13-07-2012 20:03
(T) metal pipe from water pump woes..help..... paul6693 Punto (Mk2/2b) 0 23-06-2008 21:32
(G) JTD Metal Water Pipes gregit Punto (Mk2/2b) 3 24-02-2008 02:04
