Thread Tools
Old 20-04-2017   #1
Malta
Panda not starting
Hi guys i just bought a 1992 panda that needs a head gasket. The car started up to yesterday but today it started and switched off and now wont start as if the battery is dead. It only clicks and sometimes cranks twice slowly and stops again. We tried pushing it downhill but nothing. What could it be? Thanks
P.S. we also tried jump starting it and put a good battery but still nothing
turbo93 is offline Reply With Quote Quote
Old 20-04-2017   #2
Re: Panda not starting
Check earth wire.
jackwhoo is offline Reply With Quote Quote
Old 20-04-2017   #3
Check all connections on earth wire , may be one at each end and one in middle. Make sure they are clean and tight and that crimped crimps are tight.
Do the same for the battery positive.
Old 20-04-2017   #4
Is one or more of cylinders full of coolant due to head gasket leak , that would stop it turning over.
Pull out plugs to check.
Old 20-04-2017   #5
Malta
Quote Originally Posted by jackwhoo View Post
Could it be hydrolock? Please dont tell me the engine seized it only started for 3 seconds and then gone
Old 20-04-2017   #6
Malta
Check earth wire.
But we pushed it downhill and still nothing
Old 21-04-2017   #7
Quote Originally Posted by turbo93 View Post
Take all plugs out
Jack up one front wheel 2
gear rotate wheel should turnover
If good try with starter
If starter doesn't run
Short out with jump leads
Could also be ceased starter
Check no fluid in pots
Once turning over
Squirt petrol direct in carb with an old kitchen spray.
If fails no spark
Likes turbo93 liked this post
Sjvarley is offline Reply With Quote Quote
Old 21-04-2017   #8
What panda is it photo !
Old 21-04-2017   #9
onemanmade has donated!
would strongly advise changing the headgasket, oil and filter and coolant before trying to start it?
750L Progress thread:https://tinyurl.com/m5ra2gt
1.1 Active Progress Thread: https://tinyurl.com/y86qyray
http://badges.fuelly.com/images/sig-uk/620023.png
onemanmade is offline Reply With Quote Quote
Old 21-04-2017   #10
Malta
Quote Originally Posted by sjvarley View Post
what panda is it photo !
Thanks jackwhoo thanked for this post
Likes jackwhoo liked this post
Old 21-04-2017   #11
MM nice
Old 21-04-2017   #12
Sometimes I miss my black 1000 super
Old 21-04-2017   #13
I would make sure head gasket failed myself before taking any ones word for it , unless it was someone I know
Old 21-04-2017   #14
I'm confident it won't be hydrolock damaged , but even small about fluid in cylinder could cause slow crank or no rotation of crank shaft.
You could take spark plugs out and see if starter turns over quicker.
Check negative wire from battery to body and gearbox clean connections.
Check positive wire to starter motor , clean connections.
Old 21-04-2017   #15
Malta
Thanks all for your help. Really excited to get this little girl up and running again. Some more pictures for you :-)PS this is in Malta not UK Click image for larger version
ID:	179753Click image for larger version
Thread Tools
starting problems with my panda sue starkey Newbie Central 10 14-08-2016 21:20
Panda panda not starting chelbel83 Newbie Central 3 17-02-2016 15:03
(G) Fiat panda non starting help TTR Panda 10 16-03-2015 11:26
(T) Panda 1.1 - Starting problem JD82 Panda 3 30-12-2010 21:26
(G) Why does my Panda hate starting? Welsh Jon Panda (Classic) 7 08-02-2008 22:46
