Velocemitch
Member
- Aug 21, 2011
- 99
- 89
Got a pretty bad oil leak on my daughters selecta.
In her infinite wisdom her answer to this was just to keep randomly filling the engine oil up, so now not only is pissing out all over but their must be about two or three litres of oil in there more than there should be.
My main worry is if the oil is coming out of the transmission or not. The level of the selecta oil looks ok ( unless I am being fooled by deposits on the dip stick?) but the leaking oil is black like engine oil, not red like the transmission fluid.
It's probably a daft question but do the selecta run ordinary oil in parts of the transmission as well as the red fluid?.
If I had to guess I would say the leak is from the area of the oil cooler. It's managed to find its way on the nsf wheel.
