General Brian the BFP (Big Friendly Panda)- 1988 Sisley 4X4
Spent all day pulling this lump out of a punto.
1.2 8V SPI
It ran without fault before removal. So next job is to clean it, replace the seals, and paint it.
Carb would be good but it should be a tasty one eh twin choke Weber ??
The cherry bombe exhaust. Should sound sweet[emoji108][emoji108]
I think we can all agree it's for the greater good.
And the plan is to keep the SPI I think. Probably needs a bit more consideration though.
SPI keeps its simple I think, some Webers would be a good laugh, but setting them up isnt going to be as straight forward or as cheap as wiring the injection system in!
We are all going to hell for killing Puntos, the fact they are likely only an MOT fail from death makes no difference either....
The puntos hart will beat faster in its new body transplanted to a much stronger body
Of a mud wrestler !
That plus the fact that I want to get this thing on the road ASAP!
At this rate the punto will become a classic well before the panda [emoji23] I wouldn't worry too much though, the bodywork had it's fair share of holes, well beyond the point of affordable repair
Panda update.
Steering adaptors manufactured and installed to prevent fouling
Engine cleaned and serviced with new crankshaft seals, sump sealant and cam cover seal (leaking areas changed). 90 amp Fiat Stilo alternator also fitted to power the additional lighting and future winch.
Engine mounted to sit 36mm lower with custom mounts
Haven't yet assessed the driveshaft clearance but it's looking positive.
127 gearbox flange also to be fitted
Also had to make some last minute modifications to the drive.
Despite attempting to reduce the effects of the 86mm lift by lowering AND tilting the engine, the passenger driveshaft tripod bearing was not fully engaged in the gearbox at the top.
A longer fiat Uno driveshaft was used
Panda passenger driveshaft length =530mm
Uno passenger driveshaft length = 555mm
127 flange doing its job [emoji1360]
All is well!
Well our problems were slightly different ,
Finding when supporting the vehicle
Allowing free hanging of suspension the off side drive shaft was only engaged by 2 the top tripod bearing out by 2/3s Fitting the longer uno shaft cleared the problem exposing another ,
Force being applied to the top of that roller Also pressure against the bearing face this would then cause fracture of the box !!
Removing the spacing washer allowing clearance
On the near side drive shaft too far engaged
As rotating wheel the shaft was hitting inner face of the tulip drive
Removing the washer also corrected this along with slightly adjusting the swing arm length by 5 mm
At the rear a slight adjustment to axel rotation was made to prevent lock up of the U.J . In unweighted position.
This would have caused cruciform loadings then a failure .
