I moved the axle only 10mm to the back, the same cause, but smaller wheels. 185-14 aggresve wheels will destroy the gearbox{ few even small offroad jumps with wheels not touching the ground for just a sec. and while landing/touchng the ground again with gas pedal still engaged the tensions between wheels movng free and those with grip will kill/mill something ,the same story while crawlng on 1st with gas pedal on in deep mud, with some object in the mud that suddenly gives a grip/traction to one of the wheels, there is no central diferential mechanism between axles in panda
} . From my/my friends experience any wheel bigger than 60cm {in diameter} will soon cause the gearbox cover or flange to explode or the propshaft to twist
be prepared=start gathering spare parts
ps: all those mishaps with bigger wheels combined with 1.2 8v punto engine.
165/80-14:
https://naforum.zapodaj.net/fe3618cef7ef.jpg.html
