Phiz
Member
Sorry for the tardy response, we're currently mid major house renovation so what time I'm getting is being eaten up, that being said I've had a good bit of time trawling through the forum tonight! The Mk1 grille on Pandino looks brilliant, half tempted to nick the idea for mine, though would be a bit wasted in black, the body colour grille really stands out in red. Look forward to seeing how you get on mounting those spots too something else well worth considering .
Last couple of delays on this axle nearly delt with (this thread so far has pretty much just been refurbing that, can't wait to move on :bang, mate who has brake pipe flaring tool should be home from Tennerife Monday and the trailing arms and rear brake flexi pipe are both due to arrive on Wednesday!
I got a spare hour so figured I'd check if there was any rust under the car that I'd not be able to get access to once the axle was back on, bizarely one of the spring mounting points at the top looked as good as new the other had some bubbles on, I attacked it with a wire brush and a chisel made from a 1" hack saw blade and fortunately got back to solid metal pretty quick...
Coated in Kurust, then back the following day with a load of hammerite...
While I was under there I had a quick look at the flexi-pipe for the brakes, I take it it's just held in place with a clip? Could not see any way of undoing it (from the car, I've already freed up the brake pipe to the master cylinder).
Didn't get too much time under there, in part as I'd just be twiddling my thumbs and in part due to storm Doris getting a little carried away and my legs sticking out from under the car into the rain! That being said, this picture pretty well shows the level of rust generally under the car, nothing I'm concerned about yet but clearly need to get on to this asap.
So retreated back to the workshop and while looking for the new bump stops I'd bought in (I knew I'd got some because they raised some eyebrows in the workshop when they arrived),
as you can see the old ones are well spent, but I did discover the rear bumper mounting brackets, one of which I sheared the bolt on when removing them...
I figured at the time they were probably very cheap so went a little hard on it, at work I had no internet access so couldn't check so figured I'd repair it anyway! I did consider fabricating a new one but figured as they look very light they were probably designed to be sacrificial in the case of a small bump the last thing the car needed was some heavy duty ones so I got to work.
Guess I'll probably see if the bolt has space and if not cut it down and then take both brackets to be re electro-plated and powder coated, I love that place, everything comes out looking like new again!
I also have rust at the bottom of my doors (doesn't everyone) but that'll be a project for another day, I've got to get the critical structural stuff spot on first before I start worrying about the more cosmetic however:
-Gold or Bronze would be a bold choice, not sure how it would look with the brilliantly retro look of your car with the red and Mk1 grille, though often I can't visualise these things and then the end product blows me away! To be fair my old Landrover had cream wheels but it had drums all round so less brake dust and like you say it was always covered in muck anyway .
-I had a chat with a mate who runs a car wrapping business and bounced some ideas off him. I had initally imagined a fairly fluid pattern over the black but I'm really not sure it would suit the car. The very thing that appeals to me about Panda's is their utiltarian simplicity and unclutured style, I think if I was not carefull then I would totally lose site of that so I'll tread carefully, some form of Panda logo could work really well though. Quite a few of the possible colour combo's we discussed I initially dismissed out of hand but then when the colours were offered up to the car they did look really smart so watch this space (well maybe in about a year!).
-Back on to the red wheels, they tend to look really smart on rat cars, which does not really fit with my plans but I've been looking a load more and still think they might be the best option. On the subject of rat look cars, I found pictures of a German Panda covered in Sacking material called the sackratte I think? Looked class though not sure how well the finish would hold up. Also you can now get rust paint, it has iron filings in it so the paint itself rusts, with the car in theory being protected and rust free underneath. It does look mad and I think it could look great on a Panda but I'm not sure I'd trust it, you put acid on to acelerate the process and if the paint underneath does not hold out you could be rusting your own car without noticing!
Apologies FDNY21 for not just quoting etc. but I have no idea how to do that, I'm more at home covered in oil than at a keyboard. Also are you considering running with a Fire Dept. theme on your car at all?? Oh and very jealous of the roof rack on your more recent edition, one day I'll make one up for my car, though no idea how I'll attach it with minimum impact on the car!
Cheers again
Phiz
Cheers again
Phiz
