Pandateria
- May 24, 2015
- 32
- 11
Hi, According to the garage that services my 1988 Fiat Panda (driven daily and not for sale), she needs a new carburettor. Does anybody out there have one for sale?
Every three to four months, the carburettor needs tweaking, otherwise the engine stalls when revs drop below 2000. (I'm in Lincolnshire.)
Relieved to know that whole carburettors don't just wear out, and I hear what you say about finding a garage where they understand the engine. Easier said than done though, so I'll pass the info on to the garage and hope it helps them fix her. Thanks ??The whole carburettor does not wear out.
The butterfly spindle can wear, but this causes an air leak that is constant. Repairs are possible.
Jets can wear, requiring replacement, and gaskets can fail due to age. Float valves can wear and cause excess fuelling, or variable fuel levels, and are replaceable.
Also, as above, the idle control and distributor vac unit can cause problems.
Replacing the whole carburettor, is like cutting off your leg instead of trimming a toenail. This is an indication that they do not know about carburettors any more and are hoping a new one would come correctly set up to fit and go. Unlikely.
Perhaps a different garage? A smaller one, with old cars around might be better.
Thanks for replying. Much appreciated. The problem seems to happen after I've driven for about 20 miles then parked up. When I return to the car to drive her home, she sometimes (but not always) stalls whenever I have to stop at the lights or slow to take a corner. If I drive the following day, the car is usually fine again. It's a mystery to me. As for the choke, I have to use it very sparingly as the engine floods at the drop of a hat, and that will also trigger 'stalling all the way' to or from my destination. Most of the time, she runs very sweetly so long as the carburettor is tweaked (whatever that means!) every three to four months. I'm in Gainsborough, West Lindsey btw.Is that happening when engine cold or warm/hot? Does it keep stalling with choke out?
Start with checking the vaccum advance unit located on the distributor unit. Just pull of the rubber hose from back of carb base and blow/suck air trough the hose - should be air tight.
There are several easy checks to follow if you want to / fancy diagnosing your panda by yourself.
Thanks. Can you recommend the best kit to buy so that I don't end up with a cheap useless kit?If the carb is at fault, it's high unlikely it will need to be replaced, it will just need a thorough strip down, clean out and rebuild with new gaskets. Kits are available for around £40.
New carbs are not available (unless you buy a Chinese knock off which I would not go near!) and any second hand one is just as likely to need a rebuild as the current one.
Thanks for replying. Much appreciated. The problem seems to happen after I've driven for about 20 miles then parked up. When I return to the car to drive her home, she sometimes (but not always) stalls whenever I have to stop at the lights or slow to take a corner. If I drive the following day, the car is usually fine again. It's a mystery to me. As for the choke, I have to use it very sparingly as the engine floods at the drop of a hat, and that will also trigger 'stalling all the way' to or from my destination. Most of the time, she runs very sweetly so long as the carburettor is tweaked (whatever that means!) every three to four months. I'm in , West Lindsey btw.
Solid advice, thanks ?Yeah. At the VERY worst your carb may need reconditioned with new jets and gaskets etc. and there's specialists on the internet that can do this. I'd a similar problem with my Panda two weeks' ago in the freezing cold mornings until she warmed up, it was fine after I adjusted the air filter wax stat and slightly enrichened the fuel mixture on the carb; haven't fully tested it as it was just before she was left in for major bodywork so won't see her again for two months.
You need a mechanic who knows how to deal with carbs, adjust timing and know what a distributor is! My mechanic is ex Fiat but semi retired and in poor health and younger boys generally don't want to know so you get responses like 'you need a new carb' as if it's like replacing an ECU that can't be repaired. I've heard of this a few times recently but if you look about locally and on the internet you should find experienced guys including too younger ones who work at older cars. Certainly don't be replacing a carb!
Does really sound like that solenoid sticking, it cuts the fuel through the idle circuit so you can make the engine run with your foot on the throttle but as soon as you lift off it will not idle at all. Possibly a break in the wire leading to it, might explain why it's intermittent/ heat related. I'm up in Epworth btw, work down in Retford so not a million miles away from you.Thanks for replying. Much appreciated. The problem seems to happen after I've driven for about 20 miles then parked up. When I return to the car to drive her home, she sometimes (but not always) stalls whenever I have to stop at the lights or slow to take a corner. If I drive the following day, the car is usually fine again. It's a mystery to me. As for the choke, I have to use it very sparingly as the engine floods at the drop of a hat, and that will also trigger 'stalling all the way' to or from my destination. Most of the time, she runs very sweetly so long as the carburettor is tweaked (whatever that means!) every three to four months. I'm in Gainsborough, West Lindsey btw.
