Technical its getting hot in here... temperature advice 1.1 selecta
shropshire
Hello!,
I have just purchased a selecta again, I cant tell you how much I love this thing already, but I do have some niggles to get to grips with.
1) when I turn the car on the temperature jumps to 90, then carry's on going as the car warms up to the end of the temperature gauge
I have read the ECU and the engine temperature is reported correctly, just the gauge is wonky
2) Injector light is on, the fault reports as air temperature sensor
can any one tell me where the air temp sensor is, and where to get a replacement from, and the coolant temp sensor for the dash, where is this bugger?
Hiya
If you search on the "sticky" I have uploaded all the Selecta manual pdf
Just to follow up on this one, I replaced the air temp senser in the throttle body and it solved the injector light. I played it safe and did the HG as its not an expensive job. On closer inspection its the gauge or wiring for the dash temp gauge thats the issue.
I will strip and check but as a work around I have setup an additional gauge for it.
Getting there slowly, had a few other niggles but really enjoying being in a selecta again.
