Hi all, time for a quick update on the 4x4 Panda that I got a few weeks ago, have been snowed under with uni work this week.... Thanks for the locks Tony, apologies as I forgot to mail you sooner.
Anyway, the Panda's in the workshop, and have replaced the rear UJ, and stripped and re-greased the two front CV joints, though one has a bit of play, should go on for a while yet...I need to find some boots that fit the CV joints as well as the originals are pretty knackered.
I've welded the hole in one side of the scuttle panel, smoothed and repainted, pleased with the result on that one. Also managed to get the new windscreen in with no drama, much easier than getting it out.
Have now got the front hub carriers and balljoints off, which could do with replacing, one is totally shot, the other rubeer is split so probably needs renewal anyway. I have also removed the driveshafts, as both oil seals are a bit leaky. They are the older type, with plastic bush and oil seal rather tnhan ball bearing type. Does anyone know if the newer type boot/oil seals will fit the older type shaft as it looks like a slightly better system? Hayne says they changed in 1987.
Otherwise, just small jobs like fiddling with the dash electrics which have been chopped about a bit, but it's nearly all working now. Have found a small rust hole in te back of the right sill which needs cutting out and replacing, a bit fiddly but the other side is almost like new!
Also found the genuine panda roofrack that I've had stashed in the shed for years and put that on, I think it'll make a good basis for a light rack, but that will come later...
Think that's it for now, will stick a few more pics up when i have a bit more time...
Cheers, Mike
Cheers, Mike
