You might see this type of thread before but I was wondering what's the best way to get more power out of the 903cc, I know the obvious answers like a better carb and air filter but what else could bump the power up without a engine swap, thanks in advance for any help
and if I do increase the power I will need better brakes
Echoing what MEP said, brakes might not need anything, I'd much rather spend money on decent tyres. My stock brakes can easily lock the front wheels even from 35-40mph.I will need better brakes and try to reduce the body roll and get tyres and wider wheels to allow more grip and I'll try to keep you updated as much as possible
Oh right it's just I was told if I increased the power I'd also have to improve the brakes
Will do thanks for all the advice and what would need doing if I put a 100hp engine into the panda
TA won't think high wise from what I've heard, I think VmanC has tried/looked into it.
Have a search on here, been done several times and should have all the info you require.
Not sure about the height of the TA, it's the 500 Abarth that I found was very tall, probably too tall for a Panda. I'm only at the tape measure stage though so may be proved wrong when I physically offer it up.
Got to ask, where would you get a TwinAir or 500 Abarth engine from?
Well I already have an Abarth engine, but if I didn't I'd be looking at scrapyards and eBay.
Have quite a few TAs and Abarths been crashed already?
