Does the front look a bit low now.. does it need a lift kit..?
Sorted, we're both pleased with the new front look as now the car looks leveled up with sills paraller to the road.
Loving the word "paraller", fantastic. Have you just added the skoda springs then?
Should I say " equidistant at all points, and never converging or diverging"?
Yes, 5 door rear felicia NOT estate.
Ah so that's more so why it looked a lot higher at the back, well it looks good for that bit extra.
As the transplant discussion has started in LVJ thread regards FIRE engines here is a table which i found online some time ago.
It shows basic info and some interesting motors available in Brazil.
some oldschool sharp file and a pair of skilled hands will do the trick, but why not to use electric low press pump for carbs? Pump in my 0.9 ohv decided to give insufficent pressure, so as a quick temporary bodge{ right, temporary, it works for over a year like that} I used spare fiat 130 pump, old 45 years old Facet electric fiat spec. pump. All works well wth 0.9 ohv carb equipped with fuel return pipe. In "fire" family engine without lobe and rod for fuel pump and without fuel return pipe at the weber tlf carb just use "fire" mechanical fuel pump , it will not be proppeled by the lobe, but still it will serve as a fuel return sender to the tank{it has two "one way" spring valves inside , pressure from electric pump will open/operate them}, just remember to put the working low pres fuell pump between tank and mechanical one .some modern CNC / lathe could do that for sure.
