Albert Alfvag
Member
Hi again.
today I removed the fuel pump unit from the tank. Everything was connected correctly so no closer to a solution there.
the pump "looks" okay on the outside exept for one thing. The filter sock on the bottom of the pump has a tear in it, not very big, about 5/8th of an inch.
Could that have let some dirt through into the pump causing it to not work correctly under low pressure (idleing)?
On the pics you can see the pump and the tank, which seems to be in pretty good condition.
