| Banned | how to change a timing belt.. i dont know if i have already posted this, but here it is again - to change the timing belt, remove the plastic covers, cut half the timing belt off (length ways), slide the new timing belt on (so its half way on), then cut the rest of the old belt off, then slide the new belt on completely, that way you dont have to mess about with setting the timing again, then all you have to do is put the plastic covers back on - done
| | #3 | ||
| Banned | Re: how to change a timing belt.. i dont fit a new tensioner, as its a metal one, its the plastic ones that give trouble.
| | #5 | ||
| Re: how to change a timing belt.. ..Sounds like a clever trick to me!!!Good thinking!
| | #6 | ||
| Moderator | Re: how to change a timing belt.. This is an old trick. I do this when changing the belt on 8 valve FIRE engines as they are non-interferance. I wouldn't do so on a non-FIRE engine though. I'd leave the tensioner as well Chris, if it goes then just fit a new one and you're off again.
| | #7 | ||
| Wide arch Hormann Turbo | Re: how to change a timing belt.. For the price of a tensioner(£15 form Fiat) there is no point in leaving the old one on there as if the old one starts squeeling then you have to do nearly everything involved in changing the belt again all for saving £15?
| | #8 | ||
| Re: how to change a timing belt.. How do you get the belt over the lip on the water pump?
__________________ Pete, Clubcento technical bod. Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento | |||
| | #9 | ||
| Moderator | Re: how to change a timing belt.. I'm a tight git though. ![]()
| | #10 | ||
| Wide arch Hormann Turbo | Re: how to change a timing belt.. instead of cutting the belt why not just set it a tdc first then take the belt off? ive never had any trouble doing that.
| | #11 | ||
| Wide arch Hormann Turbo | Re: how to change a timing belt.. set the engine at tdc undo the tesioner remove the old belt then put the new belt around the crankshaft pully then the water pump then slide it onto the camshaft. I would always get a genuine Fiat belt as the are only about £5 more that a motor factor and they come with lines on them that you line up with the marks on the pullys then you know you are timed up antd the pullies have not moved.
| Cost of Marea 20v timing belt and tensioner change | marea2111 | Marea > Technical | 5 | 28-04-2006 21:44 |
| Timing belt change under 12K? | bovine | Punto > Technical | 3 | 19-07-2005 08:37 |
| CAMSHAFT LOCKING TOOLS (Haynes Manual) NEEDED FOR TIMING BELT CHANGE.... ON EBAY NOW! | dbriglee | Auction Watch | 0 | 07-02-2005 09:52 |
| Photo how-to: Marea 20v cam belt change | fixitagaintomorrow | Marea > Technical | 0 | 01-02-2005 13:20 |
| Timing belt change | panichat | X1/9 | 2 | 25-08-2004 23:06 |
