the 8F is the ECU i currently run.
i am not sure if just swapping the ECU would work. if it has the 16F, it will have a built in immobiliser. the 6F i dont think will have one.
i think if you take the ECU and loom from off the 999cc engine and put it on the 1.2 engine it should work fine.
