hmm agreed. you can get a 1.1, a 1.2, and a 1.4 engine in 8v
i went with the 1.2 because it had better fuel economy over the 1.4 engine.
i intend to drive the car as economically as i can. fuel injection with auto fuel cut out will help a lot. and so i have been told, the punto 75 engine supports this.
the thing that would kill the gearbox is hard acceleration, "power shifting", racing it, and just general abuse like that.
this car was never designed to be a race car. so basically, don't drive it like one and it will last a long time.
even the punto 75 was never designed to be raced. it was more for higher road speed use, say if you had to travel on a high speed road way often.
if you are looking for a car you can use for fast take offs and quick acceleration i don't think the panda is the car for you :/
put it this way, i am in 5th gear travelling at 30mph (50km/h). you spend so much time shifting gears in the 4x4 panda you would not really get anywhere if in a race. i can only guess that this would be worse with the 1.2 engine as you would have to shift quicker through the gears, making it more easy to make a mistake and miss a gear wish can be fatal for a gearbox.
my advice would be to go for a road going 4x4. one that is not meant for off road usage.
if you get a panda though, we will help you best we can with any questions you have.
