If this car could talk I wish it would tell me what to do next
Right the issue is following the break down on the way back from the classic car show problem would appear to be the timing. I've checked the cat ie run it without the lambda censor problem continued no usable power.
He will rev up standing still but no heart under load. new plugs no change, new leads no change and spares coil pack no change
Fitted new timing belt from Fiat correct belt 125 teeth timed up with crank timing mark and upper cam shaft mark turned the engine over by hand two full turns marks on belt and engine and cam belt markers spot on.
The only thing the timing is still out using the strobe light on the marker in the bell housing it's retarded by 15 deg.
So what the hell am I missing
