Lamps by Post - For all your lighting needs
Thread Tools
Old 31-03-2014   #16
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Snowboard Slalom Champion, Skate Boarder Champion
Re: Dead Panda
hey at least its not a GP
Likes Didge3 liked this post
Charmander - Panda Mania 1242 mpi 8v - thread
Unnamed - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT
blu73 is offline Reply With Quote Quote
Old 31-03-2014   #17
Big is not always better
scout's Avatar
scout has donated!
Re: Dead Panda
It's nice to know that I can't completely balls it up. Gives you the confidence to give it a go.
Likes Most Easterly Pandas, homeward liked this post
Gotta' luv goin' topless
Be wary of little Fiats they get under your skin
My 500 has an older cousin (Classic Panda)
scout is offline Reply With Quote Quote
Old 31-03-2014   #18
onemanmade has donated!
Re: Dead Panda
Quote Originally Posted by scout View Post
The non interference thing is great!
750L Progress thread:https://tinyurl.com/m5ra2gt
1.1 Active Progress Thread: https://tinyurl.com/y86qyray
http://badges.fuelly.com/images/sig-uk/620023.png
onemanmade is offline Reply With Quote Quote
Old 03-04-2014   #19
Spanners at the ready
firecolour's Avatar
firecolour has donated!
Re: Dead Panda
Another vote that this is a pretty easy job to do. I'd add to the notes in the link above by suggesting you take the spark plugs out as well, makes turning the engine over really easy.
Haynes has it covered but as mentioned, just make sure of the timing alignment before the belt goes back on, there are two turns of the cam for every turn of the crank. You need to find yourself a reference (eg No 1 piston at top dead centre on compression stroke and about to fire ignition) else you might set it 180 degrees out and it won't start. If that does happen, it is easy enough to slip the belt off, rotate the cam 180 degrees and pop it back on.
From a mechanics point of view, always rotate the engine in the direction it normally turns (turn the starter over once to check if you are not sure).
firecolour is offline Reply With Quote Quote
Old 14-04-2014   #20
scout's Avatar
scout has donated!
Re: Dead Panda
UPDATE:
Finally got the thing stripped down and found the water pump is also FUBAR. So now waiting on a new pump
Old 14-04-2014   #21
scout's Avatar
scout has donated!
Re: Dead Panda
Po is now fully functioning although the list of things to do before the MOT is growing. The latest is that the engine mounts look shot.
Old 3 Weeks Ago   #22
Re: Dead Panda
Was really dreading having to muck around with the timing belt, going to check it tomorrow and if needs be I'll have a stab at it. Cheers!
crumbtoasty is offline Reply With Quote Quote
Thread Tools
(T) panda 1.3 diesel dead bobbyg Panda 6 26-03-2011 15:26
(T) Is my panda dead? Rotski Panda (Classic) 14 24-07-2010 13:11
(T) Dead Panda - be aware tomlee Panda 18 19-03-2010 17:05
(G) Dead Panda :( forevertom Panda 15 15-09-2007 02:29
