I was driving to work this morning and came up to a junction so I braked then depressed the clutch and selected first, waiting till I could exit the junction, when all of a sudden it sounded as if the car was revving heavily, the accelarator was not pressed, and I put the car into neutral, and the heavy revving sound continued, I then exited the junction and the revs returned to normal, it did not feel as if it pulled out to heavily under revs either, I then parked up and used the same pedal method to park and the same thing happened. Can anyone explain this? Is it a clutch problem?
