Hi all.
I am changing Belladonna's coolant today. All part of my learning experience!
I have flushed the radiator out and it all seemed remarkably clean, which is encouraging!
I am now re-filling it. I removed the bleed screws, but coolant started coming out before I had put in the amount that I was expecting. Is that normal? I have filled it to just below the top of the expansion tank neck but I have not managed to get the full amount in. Doe te amount go down once the engine is started?
The instructions of what to do next differ in the owner's manual and the Haynes manual.
The owners manual says start the engine and unscrew the plug from the heater hose until coolant comes out.
In Haynes it says replace both bleed plugs and run the engine until the fan cuts in, then allow it to cool. Then re-fill as necessary.
Which do I do? I don't want to trap air in and blow an HG!
