chlblnz
- Mar 16, 2012
- 59
- 22
Hi, I've searched all over for a method for removing and installing the fuel pump assembly. I've managed to get the unit out of the tank via the access hole under the rear seat. To do so, one of the metal springs had to be disingaged so the sender was able to move around. It just seems the hole isn't big enough to have the whole unit with springs attached to go back in. I can get it in with one spring off but have no way of attaching the spring once the unit is in the tank. Does anybody know of method to get the assembly into the tank fully built?
