- Aug 21, 2012
- 169
- 71
In the rear brake assembly, is the "elbow" part of the handbrake lever part inside the drum supposed to hinge or move on itself? It's two joined pieces of flat metal with what looks like a pin. It's locked solid although the handbrake does move the arm OK, I wondered whether it's supposed to hinge at that joint (inside the brake drum) or it was just made out of two pieces of metal meant to be a fixed L shape?
