quick question, can you get replacement relays for the fuel pump??
i have 2 relays together with a big fuse attached to each...i think these are leaving an open circuit cos checked the amps with a multi meter....
Red lead off battery, connecte red lead to batter from meter and black to red lead on car, check meter, noted the number, fitted car cable back to battery, same figures(this with ignition off), removed relays and checked again, ok, added relays and checked again, lower reading by 0.10..........started up, running checked battery output, healthy charging, stopped car, ignition off, checked battery again with meter and it constantly dropped by 0.01 every second.......
these relays have a 3C stamped on them and have 6 spade connectors...
any help?
any help?
