Bart, by any chance ( i hope you do), you know the fiat part number for the M12 strud to hub bolt? y10 and panda ePer is showing the wrong one - M10 as fitted to 2wd.
sounds like you started the demolition a while agoTrekking ended its journey, I am starting the demolition
I trust you've got some cunning plan to mount it, and not just bolt it to the front panel :devil:
This is how i'm planing to mount mine, I'll go for nylon rope so the leading /guide plate is much smaller.
Damn, and I ingenuously thought that tigerseal and cable ties will do the trick:bang::bang::bang::bang::bang:I trust you've got some cunning plan to mount it, and not just bolt it to the front panel
It is big quad bike winch{ range is from 2000 to 4500 lbs}, but small toy compared with landrover's or patrol's winches Still reasonably lightweight, arround 15 kg, the next 5000 lbs is 24 kg , and that is a biiig difference with only 500 lbs pull gain. . It should fit clear under the 86-2003 bumper, I'll have problem with smaller 80-86 bumper, but it is just plastic, some swift anglegrinding and it will fitCan't get the scale from @Bartpandas photo but the winch looks pretty big.
