Also, does anyone know what this is?
It was mounted with the radiator, above the fan. Not sure what it does so it's mounted above the fan again, in as much of a similar position to as before as possible...
its the cars flux capacitor, once you hit that magic 88mph.. oh boy. you'll be seeing rainbow stars, Nyan cat style..
in reality, its just a resistor that makes the dipped beams come on with the side lights but really dimly.. every-things more fun inside my head.
heh they're not an MOT needed item and mostly they fail within 10 years lol they break a lot faster if your an idiot like me and run a screw driver through the resistor coil making the headlights go dimmer and brighter saying "ooohh a resistor, wonder if it makes the cabin fan go faster and slower if i short it out".. dont recommend it as it blows the fuse (i found out that it is on its own individual fuse in the panda.. kinda cool really)
i know most people disable it when they stick LED side lights in as the orange glow from the dipped beam makes the LED side lights look naff.
try it out, stick side lights on, then have a look in the light and you will see the dipped beam lit ever so slightly (if the resistor has not burned out already due to age).. then on that resistor pull off the red wire and it will go out but the side lights will stay on. when putting the light switch so the main headlights it does not effect it. and they work as normal.
like i said, a lot of them dont work. i love all my wireing to work A* so i just had to get the one on my panda working again heh.
this is the first time... and last time i'm drinking an energy drink -_-
