- Jan 11, 2012
- 86
- 18
Hi everyone,
My 1992 Fiat Panda 'Sky', with the 1000 FIRE engine, has been sitting in the garage for too long and deserves an MOT. In theory it should just fire up and drive to the MOT station, but I can't get the engine to fire.
The problem started with a bust water pump on a holiday in the Peak District. The engine overheated and blew the head gasket. I replaced both, then a few weeks later the timing belt went in summer 2010 and it's been garaged ever since. I replaced the timing belt, but then the radiator cracked in the winter (someone told me they'd antifreezed it when they clearly hadn't). Then something seized in the carb, so I sent that off and had it fixed. Then the new head gasket blew (I didn't fit it properly). So I've just replaced the head gasket again and connected up the timing belt, but... nada.
There's a spark, there's fuel, and there's air, so I should be getting something? The engine turns on the starter but doesn't fire at all.
Has anyone else had trouble getting the timing marks to line up properly? I've always found it a right bugger and I'm still not sure if it's spot on, but if I move it one tooth in either direction it's still wrong.
Or could the problem be at the distributor end? I marked the distributor before removing it so the casing is lined up as it used to be, but what about the rotating arm inside? If that has been rotated 180 degrees, could that be causing the problem?
I'd really welcome your advice!
