Hi gents,
Back again as promised with another 1986 Panda 4x4 to keep company to its Sisley sibling. This time driven all the way up from Nottingham. The car is in very good general condition, the engine has had some new parts fitted and is very clean with no rust, the bodywork is in superb condition apart from both lower door panels (the sills are ok, though). The sound of the engine both on idle and with gear engaged was fine and the car drove o.k. The only problem, already stressed by the seller as such, was that when accelerating, especially with 3rd and 4th engaged, the car had obvious flatspots, you felt the acceleration was intermittent, the same when on throttle. I thought it was probably down to the fact that the engine needed a good clean up, maybe with something like Redex. So, I was about to take pictures of the Sisley and my recent acquisition and post them for you, and then go on with my sisleyfication plans, when disaster stroke (so to speak)!
Yesterday morning the Panda engine started off as usual, I let it run for a while in idle listening to the radio in order to warm it up, then it seemed to me it started loosing revs so I switched it off. Then it would not start off again (the starter motor would engage but the engine simply would not start). When I came back from work the same evening, I had to move out into my girlfriends apartment, so I gave it a try just in case and... it started off without a hussle. However, today it was more of the same. After I switched the engine off it would not start again. Only this time after 3-4 attempts to start the engine off the starter motor faded away to the point of not responding at all and it would not even jump start with the aid of jump leads. Have you got any idea what the problem might be? Have you had anything similar in the past? Any help would be really appreciated as always. Thanks.
P.S. Sisleyfication will go on one way or another, after I solve this little problem, I'm already getting quotations from mechanics for the job.
