Technical Fitting Punto/Seicento seats.
VmanC
The Panda whisperer
Alton, Hants.
This has been a long time coming but finally I can let you all know what's involved in fitting these seats.
Firstly, can I dispence with the rear seat options. I decided not to use them in this installation as it appeared that the amount of work needed to get them in just wasn't worth the effort. If someone would like to have a go, great, I look forward to reading how you did it ;). Having the rear seat match the fronts is very desirable though, so here are the options I would consider :-
1. Use the material from the rear seat to make, or have made, a cover for the Panda rear seat. There probably won't be enough material to do this without sourcing some extra to suit. If the seat trim has black in it, as in this case, it should be quite easy to do, or you could even buy two rear seats to ensure you have enough. Not as daft as it sounds as sometimes you can buy these interiors very cheaply.
2. If you're lucky you could find some Punto/Seicento seats that are a close enough match to your Panda rear seat, which is what I have for this installation. This simplifies things a great deal as you only have to buy and fit the fronts.
3. Check out other cars as a source of alternative seating, with a rear seat that will fit easily. I know Diahatsu Sportrak seats will fit, I have them in my 750L, and will be fitting another set soon into another Panda for someone else. I will post a new thread covering this option.
Ok, fitting of the front seats.
They can be bolted straight to the Panda floor once you have removed the Panda seat runners that are nearest the doors. The Punto/Seicento seat frames are just too wide to fit between the Panda runners and reach the floor, unfortunately making this necessary.
First job is to remove the old seats and carpet, also any sound deadening felt you find under there. I recommend using an angle grinder to cut out the seat runners and these produce alot of sparks, so anything flammable needs to go. You will now see that the wiring loom runs next to the o/s runner, and the rear washer pipe runs next to the n/s runner, ensure you are aware of there existence when cutting, cover them with a piece of wood where you can, then move them towards the middle of the car out of the way when this becomes possible.
You are now ready to cut across the top of the runner with the angle grinder. I stood up pieces of scrap plywood around the area to stop the sparks travelling too far, if you don't do this you run the risk of setting something alight, plus, the grinding dust will get everywhere and be a pain to clean up. A couple of pictures will best explain the actual cutting......
You can now see where you need to cut with the angle grinder. Once you have done this across the top you can then wiggle the runner in and out to weaken the spot welds that hold it at the bottom to the inner sill . As they weaken they will be easy to see, you can then use a chisel to cut down through them. It's then a case of tidying up the top edge a bit, either with the angle grinder or a file, then painting the bare metal. The spot welds will probably leave tiny holes in the sill, you can just see them in the second picture. This picture was taken after I had painted the area but before I decided I will fill the little holes after all, so my recommended order of jobs is.... Angle grind through top of runner, weaken spot welds and chisel through, clean up top edge and fill spot weld holes, paint area.
This doesn't have to end up looking too pretty unless you want it to, because once the carpet and seats are back in none of it is visible.
Now we are ready to drill the holes for the seats. The positioning of these holes is fairly critical to ensure that the seat adjusts freely, and also when you drop the bolts through and you go underneath to put the nuts on, you don't find that the bolt has come out inside a box section and you can't get to it. No, I didn't learn this the hard way :p. Because this is important I'm giving you a picture of each hole as a guide, please check carefully yourself before making the holes! ........
I now suggest you fit the seats and check that all is well before you reassemble the rest of the car. Once you are happy that all is well take them back out, and refit the carpet etc. When you fit the seats back in, use a screwdriver or similar to push up through the bolt holes from underneath and through the carpet, a little wriggle should be enough to open up the carpet for the bolts to pass through.
These are the bolts I used, cup of coffee is for size reference and keeping me awake :p...........
These socket headed bolts must be used as the head fits easily in the seat runners. A washer and nylok nut is then used under the car. Bolt size is M8x40mm. The ones I used were stainless steel, this is desireable rather than essential as they won't rust, therefore making any future removal easier.
One other job to cover, the seat belt buckle. this can be transfered from the Panda seat to the Punto/Seicento seat with a small modification. I wasn't able to take a picture of what is required at the time I fitted the seats, so will add this later after I have modified a spare one.
So here's the end result............
A vast improvement on the originals for support and comfort, rear access is still the same, as is hight and available adjustment. Also, to my eyes, they look pretty cool too. Long journeys will be much more of a pleasure in future :).
EDIT.
Just noticed that in the fourth picture down ( second picture of holes ) there are two holes showing, the top one is the one you want the lower being a hole for the cable that holds the wiring loom.
nicely done,MPI sei seats are nice seats
you should make it into a guide so its easy to find
https://www.fiatforum.com/guides
Will do, thanks.
You seem to recognise the seats, could you confirm for me what they are from as I'm not familiar with other models in the Fiat range and didn't see the car these came from, I was originally told Punto sporting?
Will do, thanks.
those are sei MPI seats (might be fitted to a punto to though)
eg http://cgi.ebay.co.uk/FIAT-SEICENTO...iewItem&pt=Automobiles_UK&hash=item1c10e7e6dc
i had a set for my old turbo cinq(never fitted :(
they are the best seats from the cinq/seis
nice and supportive
Thanks guys (y). I think that when I title the guide I'll leave off the Punto bit just in case, although fitting Punto or most other seats would probably follow the same procedure, but don't hold me to that. :(
Presume you need the runners from the donor vehcile to then? do they unbolt from the donor car or are they welded like panda?
The runners come already on the seats, the Panda is fairly unique in having half of what you need welded to the bodywork. The seat is bolted into the Panda using the same four holes that are used to bolt it into a Seicento, so nice and easy. :)
on the front arm bit that bolts down its 3 holes though two behind and one infront. how does 4 work then?
The three bolts you mention are no longer used, just fit them in the holes and tighten them up.
The Seicento seat frame is held in with four bolts that fit in a completely different place, where I've drilled the holes in the pictures in fact.
Been thinking, i guess you have to cut the orginal runers out cause they foul on the new ones/ seat? i'f i did this i would ideally like to leve them be...
You'd be better off finding seats from a different car in that case as you're right in thinking that the original runners foul the Seicento ones.
You would then keep the option of putting the Panda seats back in the future.
This mod is best kept for vehicles that are not going to be used on the public highway as the removal of the seat runner may be classed as a chassis modification that is significant enough to contravene VOSA regs.
I have a broken drivers seat on my seicento. Will a seat from any other model fiat just slide onto the runners without taking them off
Welcome to the forum :)
Whilst I applaud you for using the Search facility, not only is this post 8 years old but it's also in the Classic Panda section. Since you're asking about a Seicento, you should post a new thread in the Cinq/Sei section. But to answer your question, no, it's not that easy.
Most informative thread.
I fitted Seicento seats without removing the original factory runners. This was to go to the Sahara and back , using the method seen in another thread for fitting of Mazda RX8 seats. i.e. bolt steel angle to runners and then bolt seat to steel angle. The drawback here is that as rightly pointed out, the Sei frame won't quite fit between the Panda mounts so even after removing for/aft adjusters you still sit slightly higher up and of course have then no adjustment. Having said that they were extremely comfortable and the higher view proved quite useful off road. If you are under 180cm its actually ok, but for taller drivers probably not. Most other Pandas on "Panda Raid ' had seats bolted to floor ( including some Swiss who have rules for everything). Alfa 147 being a popular choice, but I saw Opel and early MX5 plus all kinds of aftermarket stuff. RX8 seats might weigh 10tons. One thing I would add is Panda floor is not so strong and welding a plate or at least using a super large washer each side per attachment is maybe a good idea.
I also wanted to be able to put my old seats back for originality later . :)
