The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Firela Motors - Your South London FIAT Specialist
Go Back   The FIAT Forum > FIAT Cars > Panda (Classic)
Old 03-07-2009   #1
Makka Pakka!
dvere's Avatar
dvere has donated!
Slovakia
Filler pipe repairable?
Argh! A case of two steps forward and then one back!
My 750 is all road legal having got tax the other day, so first stop local petrol station to fill up for the first time in five years
Remembered not to use the diesel pump by force of habit but as I'm stood there noticed a stream of fuel coming out from the bend in the filler pipe
I've managed to split the pipe on the 'top' of two of the corrugations right at the bottom of the bend, just about the worst place it could have gone where any fuel in the pipe will sit.
Do any of you have suggestions as to what I might use to repair this or am I looking at a hunt for a replacement filler pipe? ISTR someone making a type of tape that was petrol resistant but can't recall who or what it was called and my google-fu has deserted me.
Ant
dvere is offline
Old 03-07-2009   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Most Easterly Pandas has donated!
Bolivia
Re: Filler pipe repairable?
You can indeed repair them. I've had to do it on my 4x4 (pipes inpossible to get). Can't remember for the life of me what stuff it was though.
Or alternativly you could get a replacement (PM me )
Jon.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
4 Classic Panda's, Aswell as a 2004 Panda and LPG'ed Stilo both in Blue
Most Easterly Pandas is online now
Old 03-07-2009   #3
Makka Pakka!
dvere's Avatar
dvere has donated!
Slovakia
Jon.
Might well be doing so Off to look at a potential parts donor this weekend though not sure what's left of it at this stage though.
Meanwhile I think I'll try and tack the splits up with a soldering iron and then wrap it up with some of this Silicone Self Fusing Tape AKA "Kraken Tape" as there's a Maplin on my way home
Ant
dvere is offline
Old 03-07-2009   #4
Trader Rating: 1
Soak some of the Kraken tape in petrol to see what it does before using it. If it degrades I would be warry using it.
Epoxies tend to be petrol proof, you could repair the rip with chemical metal type epoxies, though they're not very flexible.
I damaged my hose but it was near the bottom and I was able to cut it shorter. I was considering replacing it with a PVC pipe, I measured it and it would need to be about 48-50mm internal diameter. I was planning on cutting the fuel pipe just at the top of the corrogated part and hose clipping the new PVC pipe on. At the time there was some hose on ebay, can't see it now though.
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
nitro_warrior is offline
Old 03-07-2009   #5
Makka Pakka!
dvere's Avatar
dvere has donated!
Slovakia
I'm hoping that this is the same stuff that I've used in the past by a different name, would appear so going by the picture but will test none the less.
Yup, I reckon it would have been OK if the splits were in the "troughs" rather than the "peaks", slap a bit of epoxy in there and then wrap the pipe in reinforcing tape. I have some known petrol safe epoxy and suitable tape in the shed of course.
Ant
dvere is offline
Old 04-07-2009   #6
Makka Pakka!
dvere's Avatar
dvere has donated!
Slovakia
Well the silicone repair tape looks to be impervious to petrol
Even better it is cheaper in B&Q.
Even better still it is a whole pound cheaper in the electrical section rather than the decorating one (identical product in a poly bag instead of a blister pack ).
I wrapped the filler pipe around the area of the splits with a few layers and covered it with some water proof cloth tape for strength. Seems to be holding up OK. Will stick to half a tank full for now though
Ant
dvere is offline
Old 14-07-2009   #7
Makka Pakka!
dvere's Avatar
dvere has donated!
Slovakia
Braved a full tank on Saturday (armed with a drain tray and jerry can ) and still looking good!
A big for the silicone tape I reckon!
Ant
dvere is offline
Old 14-07-2009   #8
I have to do the same job on Jim's panda soon... He split the pipe on some trip to the arse hole of no where.
I'll have a look in B&Q tomorrow, it's 10 per cent off for bears on Wednesdays
Fred
FredTheFiatBear is offline
(T) Fuel Filler Pipe Lima Barchetta 20 25-06-2009 13:42
(G) fuel filler pipe ... zulu705 Panda (Classic) 10 09-06-2009 21:24
(T) Cost of a New Filler Pipe Cig Punto 1 03-12-2008 19:24
(T) Fuel filler pipe & Festival of Speed simpson8120 Barchetta 4 15-04-2008 22:33
Fuel filler pipe disaster phatbenny Panda (Classic) 22 02-04-2005 13:14
Copyright ©2002 - 2010 FIAT Forum
