The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > FIAT Cars > Panda (Classic)
Old 03-07-2009   #16
Trader Rating: 1
Re: Panda Sisley 4x4 bittersweet yarn
Fix it. Looks to good to break.
Can you weld? For the damaged bits of roof I would be looking at cutting out the damaged sections and welding in new pieces cut from a genuine scrapped Panda. The arch is pretty straight forward repair.
What are the sills like?
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
nitro_warrior is offline
Old 03-07-2009   #17
All go, no show
lewey's Avatar
lewey has donated!
Can weld badly, but don't have kit and I don't have any other scrappers to chop up and I can't see them letting me do this at the scrap yard (that does have a gutted fizz as well). This is probably the best solution to sorting, but can anyone think of a clever "Heath Robinson" solution that will at least allow me to open and close doors without gaffer tape involved to keep the inside dry?
I will give it a closer look next week, armed with a wire brush and a hammer but my inspection at the yard didn't turn up any issues with the sills or suspension mounting points, infact it looked particularly good around the rear. The leaves barely rusty and a fuel tank that is only a year old, based on it's shininess and the last MOT failure sheet in 2008 that I looked up online. Bet that wasn't cheap. Don't suppose the prop needs to be disconnected to fit that as that might explain prop off?
lewey is offline
Old 03-07-2009   #18
You drive a wot!!??
purple haze's Avatar
Trader Rating: 2
purple haze has donated!
Saudi Arabia
Checkout MEP's roof sale.....You need and he has...Strange or wot????...Could work...
FOLLOW THE ADVENTURE.. WWW.2TIMBUKTU.CO.UK
Originally Posted by Wee Smurf View Post
I don't have a classic Panda but regularly come here. It's much more friendly in the classic section than the nuovo section.
purple haze is offline
Old 03-07-2009   #19
Trader Rating: 1
The prop doesn't need to come off to replace the fuel tank.
Now you come to mention I have a twin sunroof roof that nobody wants, unless someone decides they need it I can cut out some sections for you.
What's the damage to the roof look like underneath where the door seals? If it's just the top that's dented it shouldn't leak as long as the door seal is straight.
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Old 03-07-2009   #20
Luke P has donated!
Hi Lewey,
Result!! Bad bits aside that's a really good find... £25 cheaper than mine and in better condition. I reckon fix it is the best option... A twin sunny Sisley would be great!!
Good luck... Luke.
Luke P is offline
Old 03-07-2009   #21
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Most Easterly Pandas has donated!
Bolivia
Lewey could you confirm the colour of the upholstry please.
I've just noticed that from what I can see, its one of the origional 500 Sisleys made
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
4 Classic Panda's, Aswell as a 2004 Panda and LPG'ed Stilo both in Blue
Most Easterly Pandas is offline
Old 03-07-2009   #22
panda1408 has donated!
I was wondering if it was or not, wasnt sure with it being an F reg. When were the unlimited Sisleys first sold?
1993 Panda 1000 CLX
1992 Panda 750
panda1408 is online now
Old 03-07-2009   #23
Bolivia
Was 87 (I think, might have been 88) for about 6 month to a year (again not 100% sure) Mine was an E reg and I've seen some F. G reg was the later type Sisley. and there was 18months between the two iirc, so limited Sisleys must have been until early F reg and later type must have started late G (back then reg's only being changed anually is a bit harder to narrow down).
Old 03-07-2009   #24
All go, no show
lewey's Avatar
lewey has donated!
It's not one of the first by my understanding. It has sisley seat belts and funky dials?
I'll get back to you Nitro, I am prepping my Westfield for racing tomorrow having only finished rebuilding it earlier this morning. Manic at the mo!
lewey is offline
Old 03-07-2009   #25
Chichi and Qing Qing
pandamonius_maximus's Avatar
pandamonius_maximus has donated!
I know the feeling, things allways happen in one big torrents. Good luck in your race!!
Si
Qing Qing the rescued panda
pandamonius_maximus is offline
Old 03-07-2009   #26
Bolivia
What colour is the uphostry?
It like
Creame coloured
Old 04-07-2009   #27
Vin
Citivantastic
Vin's Avatar
Vin has donated!
If there was 18 months between the Sisley being a special edition and being a standard part of the Panda range, and as G reg (1st August 1989) is the 'standard' version became prominent, I would say that a few early ones could have been registered on an F (Say in July 1989, maybe....). That would mean that all the Special Edition Sisleys were registered on a D plate(1st Aug 86) or an E plate (1st Aug 87).
Anyway, just realised this is all irrelevant, as I am pretty sure that 'special edition' Sisleys only came in the metallic green, red and grey......not the blue, which became available when it was a standard model, at the expense of the grey.
Vin
EDIT: Just did a DVLA check for
The vehicle details for F338 TAB are:
Date of Liability 01 09 2009
Date of First Registration 16 03 1989
Year of Manufacture 1989
Cylinder Capacity (cc) 999CC
CO2 Emissions Not Available
Fuel Type Petrol
Export Marker Not Applicable
Vehicle Status Licence Not Due
Vehicle Colour BLUE
So it was March 1989 that it hit the tarmac.
And it's still taxed to the 1st September, so hit that tarmac again Lewey
On top of the Lingotto Building looking down on creation.....2000 Brava SX JTD 105, 1985 Panda 45 CL, 1986 126 FSM, 1978 Fiat 900T Citivan, 1988 Panda 1000CL (broken for spares), 1991 Panda 750L, 1991 Panda Sisley
Vin is offline
Old 04-07-2009   #28
Bolivia
Or Sorn until then.
D reg - 1st Aug 1986 - 31st July 1987
E reg - 1st Aug 1987 - 31st July 1988
F reg - 1st Aug 1988 - 31st July 1989
G reg - 1st Aug 1989 - 31st July 1990
Assuming the second lot of Sisleys came out 18months (or just under) after March 1989 it could possibly make this one a late limited one, if the early none limited ones came out on a late G plate (June/July 1990).
I'm just trying to work it out. My Sisley (one of the limited 500) was an E-reg (E956 JMO) and was registered 30 June 1988. With an 18 month delay from when (asusming mine was one of the last) you'd be looking at Jan 1990.
Thus meaning that if this is the case, the one Lewey has picked up shouldn't have been around then? I think the ages and time difference in my first synopsis is more porbably
Omg I'm getting confused now
Old 05-07-2009   #29
All go, no show
lewey's Avatar
lewey has donated!
I'm back. Sprinting went well and I came first in my championship class. I have just made a YouTube account and uploaded a video of me going part way up Shelsley.
The interior of the Panda is grey as opposed to cream.
@Nitro: Thank you for your offer. Assuming the roof is not going anywhere, I will carry on investigating the car and get an MOT hopefully, then contact you about the sections?
In the damaged sections the roof has been pulled in, away from the door. This creates a fair size gap you can put your fingers through.
lewey is offline
Old 09-07-2009   #30
All go, no show
lewey's Avatar
lewey has donated!
Concerning rear arch corrosion, how much is OK? Can I gaffer tape it up for the MOT? I am looking to get an MOT to prove it is worthy, rather than restore before taking it. Not looking to spend money or time if I can help it at this stage!!!
lewey is offline
Copyright ©2002 - 2010 FIAT Forum
