| | I wonder what happens when.... (IOTY nomination) .....an engine mount has snapped, and you remove the only thing keeping the engine from falling out of the bottom ![]() CRASH, the engine falls to the floor ![]() Remind me never to remove the throttle body from the engine of a smashed up Panda when the TB is slightly imbedded in the bulk head and holding the engine in the air ![]() Also cut my finger ![]() ![]() And found a hole in the gearbox ![]() ![]() ![]() As the hole is only in the cast, they gearbox should go again shouldn't it ![]() Jon. | ||
Posts: 475 Thanks: 13 Trader Rating: 0 | Re: I wonder what happens when.... (IOTY nomination) Clean fingernails for someone with their hands in an engine bay! Do you wear gloves?
__________________ ~ deliver me in a black-winged bird ~ 1969 Citroen AK350 1992 Fiat Panda 1242 CLX / 1995 Fiat Panda 1000 CLX 2000 Ford Focus 1.6 LX auto | ||
| | #3 | |||
Look cleaner than they did when I cut my finger.Nope, don't wear gloves, just been washed before putting plaster on cut finger Although I do keep a bucket of water by the side of the car to regularly rinse hands in to stop them getting to grubby (first time I've done it and it seems to work well ). | |||
| | #4 | ||
Posts: 3,026 Thanks: 84 Trader Rating: 0 Drives: | Your nomination is duly added - do you intend to let anyone else stand a chance for the title ? ![]() Trev
__________________ See Fred's latest excursion ! http://www.fiatforum.com/leisure-lou...ml#post2432709 ![]() | ||
| | #5 | |||||
| Join Date: Jan 2003 Location: Birmingham, United Kingdom.
Posts: 1,639 Thanks: 1 Trader Rating: 0 | Re: I wonder what happens when.... (IOTY nomination)
And yes, the gearbox may well be OK if that part of the casting is the only damage.
| The following user says "Thank You!" to John H for this useful post: | ||
Most Easterly Pandas (02-07-2009) | ||
| | #6 | |||
![]() Jon. | |||
| | #8 | ||
| | Re: I wonder what happens when.... (IOTY nomination) The smashed Selecta. I managed to almost completly strip the engine wiring loom out of it yesterday. Just got to take it though bulk head. Should have car in a stripped state ready for engine and gearbox removal by the end of the day. Engine bay looks a bit different now it's been stripped a fair bit. Surprising what you can do to bent body work with a crow bar also | ||
| | #9 | ||
Posts: 364 Thanks: 36 Trader Rating: 1 | Re: I wonder what happens when.... (IOTY nomination) Yeah the gearbox should be fine. You might want to glue a wee patch over it to stop oil and any other crap leaking in to it.
__________________ Panda 4x4 Panda 4x4 project VW Type 3 Fastback Last edited by nitro_warrior; 03-07-2009 at 16:17. | ||
| The following user says "Thank You!" to nitro_warrior for this useful post: | ||
Most Easterly Pandas (03-07-2009) | ||
| | #10 | ||
| | Re: I wonder what happens when.... (IOTY nomination) | ||
| | #11 | ||
Posts: 3,026 Thanks: 84 Trader Rating: 0 Drives: | Just drifting slightly off topic for a mo, Jon, Have you seen the new IOTY nominations from the surf mob yet ? If you want some light relief you will like them ![]() Trev
| | Most Easterly Pandas | Panda (Classic) | 9 | 30-03-2009 11:18 |
| | Luke P | Panda (Classic) | 5 | 13-03-2009 22:56 |
