The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > FIAT Cars > Panda (Classic)
Old 23-06-2009   #1
Moderator
Charlotte's Avatar
Trader Rating: 1
Charlotte has donated!
*Urgent help* - Fan
Drove 4 miles home in the Panda today, and the fan will not turn off?
It's not overheating or anything like that. The needle is where it should be
Help
1969 Singer Chamois
2001 Punto Sporting
Charlotte is offline
Old 23-06-2009   #2
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
dave doesn't view adverts
Saint Kitts and Nevis
Re: *Urgent help* - Fan
un plug it for now, or disconect battery. till some one more useful comes
Binki
Rip binki
dave is offline
Old 23-06-2009   #3
Road Rat Pilot!
default_user's Avatar
Trader Rating: 2
default_user has donated!
Sounds like the radiator thermostat is stuck in the closed position. That's the first thing I'd look at.
Rick.
The Road Rat, or Satans Rodent, is a kit car based on Panda 4x4 mechanical components.
Road Rat Rebuild Web Site
default_user is offline
Old 23-06-2009   #4
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Most Easterly Pandas has donated!
Bolivia
How long was it running for?
Disconnect, and then wait until engine cooled and re-connect to see if it still comes back on or stays off
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
4 Classic Panda's, Aswell as a 2004 Panda and LPG'ed Stilo both in Blue
Most Easterly Pandas is offline
Old 23-06-2009   #5
Moderator
Charlotte's Avatar
Trader Rating: 1
How can I check that - book says remove?
It still runs even when it's all disconnected/re-connected. It just doesn't seem to want to stop
1969 Singer Chamois
2001 Punto Sporting
Old 23-06-2009   #6
Bolivia
What have you disconnected Fan / Thermostatic switch on rad / both
Old 23-06-2009   #7
Moderator
Charlotte's Avatar
Trader Rating: 1
Master switch using red key
Also, battery. But that's the only way the fan stops. When it's all connected up again the fan starts.....again.......
1969 Singer Chamois
2001 Punto Sporting
Old 23-06-2009   #8
Slovenia
Replace thermostatic switch, it's located at radiator.
Uno driver is offline
Old 23-06-2009   #9
Bolivia
The what
Old 23-06-2009   #10
Proud to be angular
Plug's Avatar
Plug has donated!
The what
Since when did Pandas have a red key?
Cheers,
Plug
Plug is offline
Old 23-06-2009   #11
BlackCountryBlackFiat
PandaMark's Avatar
PandaMark has donated!
It's actually my car (Charlotte posted earlier as I have no internet at home again!) It's an electrical cut-off switch - vehicle has been adapted for towing behind a camper van
Update: on re-starting about an hour later, there was no response at the accelerator (no revs) I attempted to push the fuel cut-off button by the passenger door but nothing happened. Then I turned off the engine and re-tried - Hey Presto! As I drove off the fan stopped. It came on again as I sat at a set of traffic lights about two miles on. When I stopped outside Charlotte's house guess what...? The fan wouldn't turn off!
Should I book it in for a new thermostatic switch? Is there anything else more sinister going on?
Thanks,
Mark
~ deliver me in a black-winged bird ~
1969 Citroen AK350
1992 Fiat Panda 1242 CLX / 1995 Fiat Panda 1000 CLX
2000 Ford Focus 1.6 LX auto
PandaMark is offline
Old 23-06-2009   #12
Road Rat Pilot!
Trader Rating: 2
The radiator thermostat on mine is located in the plastic part of the radiator between the top and bottom water hoses as in the picture below. It may be located somewhere slightly different depending on model/year/spec but should look like the one in the pic. There will be a plug on it which you can disconnect. If the fan stops when you disconnect it, then the thermostat is your problem.
Rick.
The following user says "Thank You!" to default_user for this useful post:
PandaMark (23-06-2009)
Old 23-06-2009   #13
Bolivia
How long have you been waiting for the Fan to go off? I can run for a fair bit of time (upto 5-6 mins) after the engine and ignition have been turned off.
Old 23-06-2009   #14
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
dont be a wimp, you can change that on your own
Binki
Rip binki
dave is offline
Old 23-06-2009   #15
PandaMark's Avatar
How long have you been waiting for the fan to go off?
Absolute ages at first - I was outside chatting and I thought it was the building air-con making all the noise It's normally off by the time I've taken my bags out and walked up to the back door (50yds)
(G) Urgent Help Needed - Fan not coming on Tweedbean Cinquecento / Seicento 25 11-03-2008 01:55
(T) Engine Fan (Kinda urgent now) bigpigeon2004 Cinquecento / Seicento 4 02-01-2006 17:32
(G) windscreen (urgent, urgent) bigpigeon2004 Cinquecento / Seicento 4 08-11-2005 13:30
(T) Knackered fan motor/fan.... Adrenaline Junkie Cinquecento / Seicento 3 30-10-2004 22:28
(T) Urgent **** Help Needed****urgent barachello2000 Punto 7 18-08-2004 14:34
Copyright ©2002 - 2010 FIAT Forum
