T talbengal New member Joined May 23, 2009 Messages 13 Points 7 Location Brighton & Hove May 25, 2009 #1 Where can I found Roof Panel for my 1989 panda 4x4 ? Thanks, tal.
panda1408 Patron member Parked in the garage Joined Nov 20, 2005 Messages 2,909 Points 781 Location Leek, Staffordshire May 25, 2009 #2 What exactly do you mean by roof panel?
OP OP T talbengal New member Joined May 23, 2009 Messages 13 Points 7 Location Brighton & Hove May 25, 2009 #3 You know, the one above your head. I think its called 'Roof Panel Insert' Give you some insulation usually Grey
udtrev Twin Turbo powered :-) Parked in the garage Joined Jun 25, 2008 Messages 4,823 Points 905 Location Sleepy Surrey May 25, 2009 #4 I just spoken to Jon (Most Easterly Panda), he will be in contact later Trev
CLXCraig Patron member Parked in the garage Written a guide Joined Jun 26, 2008 Messages 3,212 Points 517 Location Hampshire May 25, 2009 #5 Do you mean the roof lining? Try a scrappy or FIAT. Can't imagine theres any decent ones about anymore though
panda1408 Patron member Parked in the garage Joined Nov 20, 2005 Messages 2,909 Points 781 Location Leek, Staffordshire May 25, 2009 #6 thought it might be the roof lining, wasnt sure though.
Most Easterly Pandas Speed Reader of the Year! Parked in the garage Written a guide Joined Aug 15, 2007 Messages 44,236 Points 7,382 Location Norwich, Norfolk May 25, 2009 #7 Hi. Could you be more precise with your description please. Is it the internally mounted roof liner, or the metal roof pannel? If its the latter then I've one I can supply Jon
OP OP T talbengal New member Joined May 23, 2009 Messages 13 Points 7 Location Brighton & Hove May 25, 2009 #8 It is the internally mounted roof liner that I am after.
