Yak
Hi all,
I just bought a panda 4x4 which drives fine except that the clutch squeels if you slip it a bit when changing up gears. I dosnt do it when you are slipping it to pull away but if you use the accelerater and slip the clutch when changing up it squeels for a second or less. If you dont touch the accelerator and just lift the clutch its fine.
Any idea why its doing this?
Ta
Yak
Ta
Yak
