Well, i have gone through 3 clutch cables in 4 months, 2 of them quite recenlty. They are being installed as per the haynes manual, and the same as any other clutch cable I have fitted to a panda before without any trouble atall....
Has anyone else had this trouble? As I beleive I know why......
I have just bought a new clutch cable in case it snapped again...and again it snapped this evening on my way back from work.:bang: Now, the old clutch cable was really stiff and would not bend through any sharp angles very well. IN fact it springs quite violently (almost caught me out putting it back in a bag). My new cable bends very easily indeed and the clutch pedal now feels like it should. Light and smooth
So in short..this is a warning to you all. There are some dodgy clutch cables for sale on ebay that are just too stiff. They are perhaps just made from cable that is too thick and once bent start to fail. Also, they pop out quite easily from the bulkhead hole because they are so springy and the cable then begins to rub on the bodywork and frays.
This might be a coincidence too....but all the cables I have had trouble with have a black plastic fitting where it fits onto the bulkhead (the bit that slots into place and turns to lock into position). The ones I beleive are correct for my panda and the one I now have fitted have white ones, but are otherwise identical.
Please correct me if I am wrong, I am now sure time will tell....fingers crossed though. I will need to buy a new car otherwise as it will be a clutch/gearbox issue and I have not got the time for that!
Hope this helps,
Cheers!
Si
Hope this helps,
Cheers!
Si
