Mega Panda White Camaleon
- Nov 22, 2008
- 9
- 4
dir friend i need your help,
my problem is this...
Well friends come here this time to get help, my pandinha which then became the photos here put up, put central lock with alarm and remote start, everything is almost the wonders whether it goddamn not was the engine's departure to trigger every 3 seconds But only when call via the control button in the normal ignition with the key ñ it happens, as we all know the panda is like the one in the ignition cylinder has a three-ply ****ch (red bulk (12v battery), red light ( start), and a fine that is the ignition), then has four more in another socket that bind almost all together, they know I not to serve, I put the manual of alarm here for a specialist who can help me because I have everything to work, the red wire from the battery called it with the red that came from the alarm module called it the green to red and yellow thinnest called him to ign refund of fuel, which are the three wires from above that will have to call something else n the yarn down? my car not have AC, so this yarn not needs to be connected, I hope your help, so the mess is the starter motor that insist on starting when the button is activated and if I leave it on is scraping every 3 seconds Thank
my alarm is Rightclick, thank
