rpm sensor did it on my puntocheers i'll get it check
Could be lot of things (dirty injectors, ignition coils, coolant temp-sender, ignition cables..... Do computer diagnostic in some FIAT service, equipped with diagnostic tools for FIAT, and they will read exact error code!cheers ive tryed the redex but still coming on
Ive change the lambda sensor yesterday and its still coming on. any ideas thanks
another culprit is the O2 sensor.
Have you tried re-setting the ECU since
Jon.
I recon it might have been the Lambda sensor, but if it's been changed
Jon.
That's what happens when you don't read propperly
I had problem with injection warning light...It was ON only for few seconds after I started engine and also I had problem to start engine...
after weeks of searching I found it out....it was BAD engine earth connection...
easy to check, easy to fix and now it's gone....of course I reseted my ECU after that...
Which earth was it again? The ECU's one or one of the earthing points
Hi
It was engine earth....
I've got Panda Selecta and starter is inside gearbox, so earth cable from baterry is fitted to bolt at the bottom (back of engine) where is some kind of cat or exhaust pipe mount. That bolt cracked and cable was hanging...so there was almost no connection...but now it's solid fitted
the little panda had in code reading done and its the throttle pot sensors. So im going to fit one and let you know now i get on.:worship:
