General Timing Belt, When to change?
SPIRITO DE PANDA
Hi folks, I have just joined this forum as the proud keeper of 2 Panda's. Can someone confirm how often the timing belt should be changed, i thought it was around every 60,000? I have a 1992 750L & a 1994 1000 fire colour.
Cheers:)
How long have you had them ?
if you don't know when they were last changed it may pay, for piece of mind, to get them changed regardless of when the recommended change interval is.
Trev
Timing belts age the same as anything else. Our old 750 threw the belt at 42,000 miles, but it had probably been on there since new :eek:
They're not that hard to change, TBH.. I got a new belt for £13 and fitted it in a couple of hours, with nothing more than mild profanity and a couple of scraped knuckles. If your timing belt is still intact, it should be even quicker..
Cheers,
Plug
If you do change the belt, take a good look at the tensioner roller. If you feel any roughness when you turn it or you can feel any slack in the bearings, replace it. If the roller fails it will take out the belt as well.
Many thanks for your replies. So i take it that if the timing belt fails on a Panda it doesn't risk damaging the engine which once happened to me on a vauxhall cavalier, cost me an arm & a leg!
The theory is it won't damage the engine as the piston can be fully up with valve fully down and there should still be a clearance gap, but I wouldnt like to test it flat out.
Our 750 threw its cambelt at tickover, whilst sat outside the house. Couldn't have been in a more convenient place..
It still never ran as well afterwards though, however this could have been due to my less than perfect attempts to re-time it.
Preventative maintenance is by far the better option than disaster recovery.. :(
Cheers,
Plug
