Technical panda headrests
LoVeDuDuTy
Bulgaria
Hi mate I have problem with my Panda I wanna remove headrests set new upholstery. But I dont know how remove headrest. :mad:
p.s. I dont speak very good English sorry!
Hello,
You need to unclip the back panel of the seat at the bottom. Put your arm right up inside until you feel the two prongs of the headrest sticking down. One or both of them will have a retaining clip which just slides off to one side, allowing you to pull the headrest out.
Good luck.
(y)
Hello again! I have tried one more time but there is no result.I want to ask you if you have some images to send me.That can help me.Thank you!
Follow instructions given by Pandafan. Shine a torch up inside the seatback and you will see for yourself.
Rgds.
I'm surprised that it is possible to take it off...
I spent all day and I coundn't :)
I thank you very much for meeting! My panda is young 900cc 1999 year. I place the pictures in else thread!(y)
I have one question how to remove the motor-horn (steering-)wheel because it doesn't work
Look at the back of the steering wheel, you should see two screws inside holes, one each side of centre. You will need a short #2 point Philips screwdriver. The horn push is on two springs and will pop out when you undo the screws.
Before you do this, check the two wires on the horn itself, situated behind the front bumper on your drivers side. This is usually where problems with the horn start.
Please let us know how you get on.
Regards.
It's hidden behind the front bumper on the gearbox side. My method is to remove the wheel arch liner then the bumper mounting nuts (two at front, one at side) and prise the bumper forward on that corner. With your car the two front nuts alos hold on the charcoal canister so its a lot simpler with the wheel arch liner removed.
cheers Damon
