The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Panda (Classic)
Old 25-07-2008   #1
CLXCraig's Avatar
Trader Rating: (0)
CLXCraig has donated! United Kingdom
Home Refurbs
Has anyone tried/done any home refurbs?
What have you tried and how have you found it?
At the moment I am in the process of refurbishing the wheels, sand down, primer, and then some good old hammerite. Looks alot better than I expected.
Next job is to touch up the front grille, the only issue I have is masking the badges. I have masked up the blue "fiat" logo, but i am strugling with ideas of how to mask off the fiat stripes in the centre of the grille.
Help please!!
CLXCraig is offline
Old 25-07-2008   #2
Chichi and Qing Qing
pandamonius_maximus's Avatar
Trader Rating: (0)
pandamonius_maximus has donated! United Kingdom
Re: Home Refurbs
Could use the "speed" stripes that go down the side of your car. Halfrauds would have that, or a better car accessory shop! I've used it before and they peel off afterwards ok too. You can buy them in a variety of widths too.
Has your panda got the girlle with lots of slats, or the one with a few and a smaller fiat badge in the middle?
Cheers,
Si
If it aint rusty, waxol it!
pandamonius_maximus is offline
Old 25-07-2008   #3
Welsh Jon's Avatar
Trader Rating: (0)
Welsh Jon has donated! United Kingdom
Re: Home Refurbs
I've not properly started the Fiat refurbs, though all of my SAAB refurbs on the old 96 have proven majorly successful and colossally satisfying!
The needing to take your part to be re-manufactured is a huge myth, go to http://www.frost.co.uk/ I've never actually ordered from them (yet) though they have been recommended to me a few times - I'm waiting to have a garage to justify spending all the money there!
Plotting Panda glory
Welsh Jon is offline
Old 25-07-2008   #4
Trader Rating: (0)
Re: Home Refurbs
hey jon!
you sciving off work?
Old 25-07-2008   #5
CLXCraig's Avatar
Trader Rating: (0)
Re: Home Refurbs
My Grille is similar, if no the same to "Welsh Jon's"
I dont really want to add anything to the car, unless its a replacement part.
CLXCraig is offline
Old 25-07-2008   #6
Ban the Mongol rally
Alan.D's Avatar
Trader Rating: (4)
Alan.D has donated! Italy
Re: Home Refurbs
The 5 chrome strips on the grille come off.....they are clipped in place.
Before doing anything....
FFS DISCONNECT THE BATTERY.
Alan.D is offline
Old 25-07-2008   #7
CLXCraig's Avatar
Trader Rating: (0)
Re: Home Refurbs
Please enlighten, i presume they are clipped in on the inside?
Pop out with a push from a screwdriver, or something more delicate?
CLXCraig is offline
Old 25-07-2008   #8
Alan.D's Avatar
Trader Rating: (4)
Re: Home Refurbs
Gently with a screw driver, if you take the grille off and turn it round you will see the clips.
Alan.D is offline
Old 26-07-2008   #9
CLXCraig's Avatar
Trader Rating: (0)
Re: Home Refurbs
Im a Few steps further with these refurbs, with the grille, I didnt want to risk snapping a clip, so I masked them and it has just been sprayed. Wheel wise, the spare has had it final coat is drying, looks a treat. The driver side front and rear have been wire brushed and are ready for priming. Its a very lengthy process but I think its well worth it, especially as mine weren't in top nick to start with. Pictures of Before and After Below.
Name:	Wheel Before.jpg
ID:	47553  Click image for larger version
Name:	Wheel After.jpg
CLXCraig is offline
Old 26-07-2008   #10
Panda's with Gadget's
Most Easterly Pandas's Avatar
Trader Rating: (0)
Most Easterly Pandas has donated! United Kingdom
Re: Home Refurbs
We've just done all the wheels silver on both of our Selecta's! They look fab
Most Easterly Panda's - Panda'ing in East Anglia
5 Panda's! 1989 F-reg 750L, 1991/1992 (not sure as on a NI plate) Panda 1000CL,
1993 K-reg Selecta (1108cc) x2! 1988 E-reg Sisley 4x4
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Pandas is offline
Old 05-08-2008   #11
Formula 91's Avatar
Trader Rating: (0)
Re: Home Refurbs
You guys have inspired me to tart up my Panda, so last weekend armed with filler and paint I attacked the near side rear wheel arch.
I am not professing to be an expert, and I'll be the first to admit my techniques are far from orthodox, but I am pleaseed with the result and hopefully it should minimise the further spread of tin worm
Attached are the pictures...
PS. The over spray on the bumper is from the previous owners attempt to 'sort' the problem - Not mine
Providing the weather is good I am going to do my wheels next weekend.
Tom
ID:	48183  Click image for larger version
ID:	48185  Click image for larger version
Formula 91 is offline
Old 05-08-2008   #12
Trader Rating: (0)
Re: Home Refurbs
You've done a bloody good job there Tom!
How long did it take roughly? Fancy doing my Selecta
Old 05-08-2008   #13
Formula 91's Avatar
Trader Rating: (0)
Re: Home Refurbs
Thanks.
I think all in about 2-3 hours, however alot of this time was waiting for filler to cure, paint to dry etc... I also a lunch break
I did also take the opertunity to clean out and under seal the whole inner wheel arch area too, whilst the wheel was off.
If you do give it a go, I recomend the fibre glass filler for major filling and also an air sander made the rubbing down a breeze.
The following user says "Thank You!" to Formula 91 for this useful post:
Most Easterly Pandas (05-08-2008)
Old 05-08-2008   #14
Trader Rating: (0)
Re: Home Refurbs
Got and used both of those in the past (or dad has when I watch should I say ), nice to have the confirmation
Old 05-08-2008   #15
Trader Rating: (0)
Re: Home Refurbs
Nice effort there!! Glad there is someone else out there repairing damaged caused by mother nature. I have been so lonely these last few weeks
To defying tinworm and beyond!
Si
(G) Don't try this at home, seriously don't! Craigdiver Punto 1 07-01-2008 22:12
um... obviously don't try this at home.. or anywhere else. Hellcat Leisure Lounge 21 14-11-2007 18:39
(G) far away from home. jayteedee Stilo 9 18-10-2007 19:46
Home And Away! Alex Leisure Lounge 5 03-09-2005 18:27
I just got my New X home Mr. X Lets Talk FIAT 3 15-07-2003 11:39
