The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > FIAT Cars > Panda (Classic)
Old 09-07-2008   #31
Re: Panda 45 in Antigua
Originally Posted by Neal376 View Post
one more guy---anyone know what these creatures purpose is?
the panda on the island has this wire twist and tied together...i need to find a soldering iron
That switch in the pic is water temp sensor, oil pressure sensor is down on the side of the block cant rember which side but it down there lol
Fiats owned to date: 1989 126BIS Fitted with 903 panda engine. 1990 126BIS. 1991 Uno 45. 1989 Panda 4x4. 1990 Panda 4x4. 1983 X1/9 (now owned by dad and receiving lancia delta hf turbo engine and box ). 1987 X1/9 VS. 1989 X1/9 Gran Finale. 1997 Bravo 100 SX. 1997 Marea 115 SX. 1996 Punto 75SX. And now 1989 Panda Sisley.
mightysisley is offline
Old 09-07-2008   #32
Ban the Mongol rally
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Italy
Any idea's about the vent on post 20?
Before doing anything....
FFS DISCONNECT THE BATTERY.
Alan.D is offline
Old 09-07-2008   #33
Been 6 years since i had a 903 engine but defo dont remember that pipe. Was just a straight breather from the filler neck to the airbox kept filling it with gunge aswell couldn't see a head gasket fault think its just a 903 thing lol
Old 09-07-2008   #34
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Italy
Thanks for looking, there must be someone with a 903 that can identify it?
Alan.D is offline
Old 09-07-2008   #35
just had a thought and hey presto, just been out and looked at my panda, i know ive got the 999cc ohc fire engine but guess what the breather got a small pipe coming off it just the same and it leads to a tapping into the manifold just below the carb. Vacuum from manifold to aid the removal of fumes from rocker cover?? thats where i would look though
Old 09-07-2008   #36
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Italy
Ah! yes so it does
Alan.D is offline
Old 09-07-2008   #37
mmm clean - that looks like a more modern system.
at idle, if i plug the hole, the engine seems to bog down a bit
Neal376 is offline
Old 09-07-2008   #38
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Italy
Look for an empty tube (like the vent that's missing a pipe) sticking out of the carb/manifold and put on a pipe between the two
Clean....yep that's my 999 sisley 4x4
Alan.D is offline
Old 09-07-2008   #39
Chichi and Qing Qing
pandamonius_maximus's Avatar
pandamonius_maximus has donated!
All these problems are so familiar lol. Regarding the starter, it could be a dead spot on the commutator (where the brushes contact the shaft within the motor). Mine used to click and then do nothing, but when it was out the car would spin up fine. I beleive this is due to the fact that when its out the car, the motor just spins on past the dead spot and carries on fine. When attached to the gearbox the flywheel increases the inertia and wont spin past the dead spot. Also, once stuck on that part of the commutator I had to get a screwdriver and turn the motor round a bit!! You can prolong the life by cleaning the commutator with a bit of fine wet and dry paper, but ultimately it is best to replace it.
As people have said already, the top sensor on the head indicated earlier is the temperature sensor.
The pipe exiting to air I would say was a previous owners bodge to try to fix the problems caused by all that muck coming out the breather from clogging up the carb. My jets were allways blocking up till I re-routed the breather into the catch tank!! I would personally do the catch tank trick, but I do beleive that the breather is meant to exit to low pressure air within the airbox. But mine has been fine exiting to atmospheric for 3 years now so I think its probably safe.
I wouldnt put a pipe down to the ground though. Unless you put a small air fliter on the end as any dirt kicked up may get into the engine as air pulses in and out from the breather.
All the best with the work anyways!
Si
Qing Qing the rescued panda
pandamonius_maximus is offline
Old 09-07-2008   #40
Proud to be angular
Plug's Avatar
Plug has donated!
the gated community i live in was built by a retired italian 30 years go when he left his seat in some high govt position in italy [i think this is how it goes]
Don't mention the "M" word..
about a decade ago he had a stroke and was unable to continue expansion of the community. he lives in one of the houses here. his fiat was left dorment just opposing his house. i moved in only a few weeks ago and got that little pasta rocket started
Let's hope he hasn't noticed you've requisitioned his car!
--dont be jealous
Yeah, right! It's been raining steadily here.. all day..
then it will be off to some crappy hospital rotations back in new york [my home town]
Was there a couple of weeks back Can't see the Panda getting much respect in the New York traffic though...
Cheers,
Plug
Plug is offline
Old 10-07-2008   #41
If you are referring to blocking the hole in the manifold where we have learned that mystery pipe is meant to go is slowing the engine, that is because when the hole is left open the engine is drawing too much air basically acting as if you were to press the accellerator pedal slightly.
Old 15-07-2008   #42
Interior stripped and cleaned - there was more sand in the carpet than there was carpet
repacked and stiched the seats
engine cleaned - some parts need repainting tho (paint is chipped)
run rubbers - engine - bumpers - shift boot - dash - all glossed
wiring...an epic mess
still havent bothered with the allignment...lazy
need to fix header leak
still havent decieded what grade oil to use here in engine and gear box
last --- there seems to be one of those vacuum advanced distributers...except know vacuum is plugged into my distributer...anyone know the vacuum diagram for this?
ID:	46873   Click image for larger version
Neal376 is offline
Old 15-07-2008   #43
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Italy
Neal all I can find are these.....
ID:	46891 Click image for larger version
Have a look at the dizzy beneith the cap and if there is a hole at the front it will be one type, if there is a hole at the back it will be the other. If there is no hole
Alan.D is offline
bit of a trek in my panda - parts, new panda, old panda panda4x4sisley Panda (Classic) 3 30-07-2006 23:45
Copyright ©2002 - 2010 FIAT Forum
