I've got a loose gearbox engine mount. I'm getting a metallic rattling sounds when i back off the gas. At first i thought it was a loose exhaust but that was ok. After more shaking i found a loose washer that goes between the gearbox mount and the body on the passenger side.
Basically the insulating rubber has shrunk causing the washer to vibrate against the body. I tried to tighten the nut from the bottom but i need to hold the bolt head from the top with a ring spanner while tightening the nut. The problem is i cant get the spanner through the tiny gap in the front of the lower suspension arm brace and lock it onto the bolt head.
If you look on the photo below i'm trying to put the spanner through the small hole about 2cm wide, 1cm high on the passenger side brace for the lower suspension arm so i can hold the bolt head.
https://www.fiatforum.com/attachment.php?attachmentid=45322&d=1213391188
Am i going about this all wrong? Do i need a stubby spanner to get into there as i only have the longer open spanner. Can these bolts be tightened? Or do you have to replace the rubber mount?
Cheers,
Ben.
Cheers,
Ben.
