| | #46 | ||
| A Panda with Gadget's | Re: Grounded Selecta Gearbox sump = Leaking CVT oil and new sump needed Right, I have fill the CVT oil. Sump gasket started to leak, but I've tightened the bolts and its stopped luckily. Now then. According to Haynes manual, the auto box takes 1.8L of CVT oil on a oil change and 2.8L from dry. I've put 1.8L in and all seems fine on the dipstick. Would this be the cirrect level or should it be 2.8L as the sump and entire oil content was removed. The only reason for asking is because there is a wyning noise on start up, which eventually goes. I used to have this for a few seconds on first start up of the day before, but it seems to hang around more. I'm just wondering if I haven't put enough oil in, but know over filling does do damage. It sounds like the hydraulic pump. Some times it only happens when the engine is over 2,000 RPM, whether in P.R.N.D.L. Thanks. Jon.
__________________ Bright in White... Look at those spots and the 240 watt of 4 Halogen bulbs!If my post or someone else's has helped, say thank you using the Thanks Button \/ | ||
| | #47 | |||
I've been told they normaly say no on first letter because 80% of people don't reply back, but I sure will! Only pain is that the sump has started leaking I think. Not enough to drip onto floor, but you can see the oil in the dirt on the sump (hope that makes sence), so will look at tightning the screws/bolts. Jon.
__________________ Bright in White... Look at those spots and the 240 watt of 4 Halogen bulbs!If my post or someone else's has helped, say thank you using the Thanks Button \/ | |||
| | #48 | ||
| A Panda with Gadget's | Re: Grounded Selecta Gearbox sump = Leaking CVT oil and new sump needed Another update. Had a letter back sometime last week saying that they're going to investigate my claim and get back to me in 30 days either with a nice cheque, or a load of bull saying it's not their fault. So fingers crossed. Jon.
| | #49 | ||
| Re: Grounded Selecta Gearbox sump = Leaking CVT oil and new sump needed If all else fails go dig a hole in the councils executive directors parking place and see how long it takes the council to repair it ![]()
__________________ What Goes Up Must Come Down..... | |||
| | #50 | ||
| Leaking oil sump! | cainey | Coupe | 6 | 20-07-2008 17:19 |
| Fiat Punto New Sump Leaking | iwannafixit | Punto > Technical | 12 | 17-06-2008 16:16 |
| Oil sump... | mitsikis | Bodyshop | 9 | 17-07-2007 17:39 |
| Oil sump needed | Martina | Punto > Technical | 6 | 03-02-2006 17:04 |
| Panda Selecta Sump? | e505jpy | Panda (Classic) | 8 | 02-05-2005 21:13 |
