Will the 999cc gearbox fit the 1242cc engine?
Yes it does:devil: My Panda is fitted with a 1242 16v and Panda 999cc 5 speed box
Any chance you have got a spare anti-roll bar?
Yes, Van Aaken did a commercially available turbo conversion for the 1108cc FIRE engine in the Cinquecento Sporting. Quite a few people have made their own home built turbo FIRE engines as well. They are generally ok but some people have had a lot of issues - mainly over fuelling and head gaskets. Have a look in the Cinqecento section as there's plenty of information in there regarding turbo FIRE conversion.
And it's not a good idea to attempt to fit a Uno Turbo engine to a 4x4 Panda gearbox. Asides from needing a modified bellhousing the 4x4 drivetrain is not designed to cope with the massive torque and power increases that will come with a UT engine. If you could fit one to a 4x4 it would simply tear the drivetrain apart
Sarano, that's some lovely work you've done on your Panda :slayer:
If you ever want to sell it, please tell me!
Cheers,
Plug
I'm interested in what work has gone on to the suspension. People generally avoid the Uno Turbo engine conversion simply on a weight basis, it being heavier than engines in the FIRE family. Thus, the oreferred upgrade is a 1242 or a 1368 16v FIRE engine (though there's still only a handful of conversions). Given that the Panda already has a nose-led balance as standard, how does it cope with the extra weight up front? The wider wheel/tyre combination will help, but I'd be interested to see if you've taken any other measures to combat understeer.
It is for sale......but it is left hand drive don't forget!
I don't have a problem with the wheel being on the "wrong" side.. how much are you hoping to sell it for?
Cheers,
Plug
Shame the link doesnt work anymore i would have liked to have seen this.
